GMTunersource
Old Aug 24, 2006 | 02:55 PM
b00st3d's Avatar
GMTunersource
I know we have our basic bolt ons for this car but what about this
http://www.gm.com/company/gmtunersou...build_book.htm
anyone running any of these set ups well the 250hp and up I know that the supercharger has no tuning yet but what about internals has anyone done em yet on the 2.2's i would definately do this before I call hann's to get the turbo kit or go all N/a depending on budget and other factors
but I was wondering if anyone put in LSJ internals or the aftermarket ones response power problems
thanks in advance
Old Aug 24, 2006 | 04:58 PM
qcpursuit's Avatar
ask halfcent about engine internal
Old Aug 24, 2006 | 05:01 PM
lightinbalt's Avatar
Yes, I think that halfcent has done the internals. I think that with the lower compression pistons u will lose power not gain. Someone correct me if I am wrong.
Old Aug 24, 2006 | 05:18 PM
b00st3d's Avatar
yeah I think you will lose power unles you go forced induction
b00st3d's Avatar
they have forged ones at our 10:1 what ever it is
Old Aug 24, 2006 | 05:30 PM
Halfcent's Avatar
I'm old school
What would you like to know? Check out my vBgarage to see my modifications. I have had no problems.
I have a set of the GMPP 10:1 ratio pistons for sale if you want to do this kind of a mod.
Old Aug 24, 2006 | 06:50 PM
Halfcent, will the GMPP 10:1 performance pistons give us more power if we dont want to go with forced induction?
Old Aug 24, 2006 | 07:37 PM
IonNinja's Avatar
no, thats the same as stock compression. your bottem end will just be stronger...
Old Aug 24, 2006 | 08:00 PM
montecarloman's Avatar
The problem with that book is that it gives you all the part numbers you need for damn near everything, as long as you own an SS/SC or a cavalier. Because the 2.2 cobalt computer isnt cracked getting a new head, cams, cam gears, and all that will only set your check engine light and put you into limp mode. Frustratin aint it
Old Aug 24, 2006 | 08:24 PM
Halfcent's Avatar
I'm old school
Thats partially true. If you do anything to fuel or ignition, the computer will get cranky. I have a full powertrain build-up, but nothing that effected those systems yet. I have a 3000 RPM stall torque converter, you can see the engine rev higher during accelerations, but that doesn't upset the computer. I have the reduced compression pistons, which has reduced the power of the engine, but that also has produced no problems. I have never once had a single CEL since my build.
I also have the GMPP adjustable can gears, but they are currently set at zero degrees, so thats just like stock. Once I get a tuning solution, then I'll play with them.
As for the earlier question, IonNinja was correct. You won't get any more power by replacing pistons with the same compression ratio. However, the pistons themselves are much stronger and can withstand up to 600 HP (according to GMPP). They would be IDEAL for nitrous or very high octane and high boost engines.
Old Aug 25, 2006 | 08:40 AM
b00st3d's Avatar
that is all yeah I want to build up the engine for forced induction later on even if I lose some power in the mean time but the damn computer crap that is what is setting me back I just e mailed the GMTunersouce link to see what did they do with their builds
Old Aug 25, 2006 | 10:58 AM
Halfcent's Avatar
I'm old school
GM racing has always used stand alone FMU's, bypassing the stock E16 unit. This works great for racing, but not for street use.
Old Aug 25, 2006 | 11:38 AM
slowion2's Avatar
Half: how much are you looking to get for those pistons?
Old Aug 25, 2006 | 03:56 PM
Halfcent's Avatar
I'm old school
$400. It's in the ad.
AlphaJaguar5
1378
Nov 9, 2009 10:54 AM
AlphaJaguar5
Mar 3, 2009 06:16 PM
AlphaJaguar5
Feb 3, 2009 02:44 AM
AlphaJaguar5
Jan 5, 2009 06:29 PM
