Got a question?!?!?!?!?!?! :(
Old Oct 11, 2009 | 02:19 AM
FASTL61's Avatar
So What Would Cause My Engine Coolant To Say ---*F But Not Through A Code?Im Stumped!I Looked At All The Wiring And Connections And They Look Good.Any Ideas?
Old Oct 11, 2009 | 02:28 AM
beercan's Avatar
Any chance that the temp. sensor is bad?
Old Oct 11, 2009 | 02:55 AM
FASTL61's Avatar
Its possible but I would think it would throw a code which it hasnt
Old Oct 11, 2009 | 02:58 AM
ColeJJones's Avatar
Bannned
same thing happened with my outside temp gauge. when i unplugged it, on the dash it read - - - *f. so im guessing its disconnected or doesnt work anymore
Old Oct 11, 2009 | 02:59 AM
007CobaltLS's Avatar
After checking the connections themselves for the temp sensor:
Check the thermostat. (Generally this is a p0128 faulty thermostat code though...doesn't hurt to check it out).
Other possible causes that could trigger this code would be:
Low engine coolant level
faulty cooling fan
faulty coolant temperature sensor
faulty intake air temperature sensor
Old Oct 11, 2009 | 03:28 AM
FASTL61's Avatar
Like I said.No codes.All connections are good.Coolant levels are up.
Old Oct 12, 2009 | 05:51 PM
Mregan's Avatar
Same thing happened to me, check your thermostat. It is most likely stuck open or closed. I took it to the dealership and that's what the problem was. It was stuck open and my a/c wouldn't blow cold because of it also
Old Oct 12, 2009 | 08:55 PM
As I stated before, check the thermostat...then go deeper...should be able to figure it out without much problem.
Do you have any problems with the car (I know you have no codes, but how is the car running, fine?)...if you don't have any problems with the car itself, then I'm leaning towards thermostat....even though you're in AZ, test your heat...is it getting hot or just kind of warm? That should be a sure indicator of the thermostat.
Otherwise, if you can't figure it out...take the car in or talk to a mechanic for ideas...sometimes you can get one to help you out without paying...just call and talk with someone over the phone.
Old Oct 13, 2009 | 01:19 AM
FASTL61's Avatar
it decided to fix itself lol.runs fune all the time.weird.ill keep an eye on it though
Old Oct 13, 2009 | 12:10 PM
ryansalazan's Avatar
mregan has it on the dot! same exact thing happened to me. didnt throw a code even tho the cool air went out and the coolant temperature was not showing. It the thermostat stuck open more than likely. If you drive on it for a while tho the cel should come on
Old Oct 13, 2009 | 02:23 PM
06C0BALT's Avatar
same thing everyone else said, if it fixed itself i'd stillcheck the thermostat anyway so it doesnt happen again :p
Old Oct 13, 2009 | 02:34 PM
FASTL61's Avatar
Eh ill wait im too lazy ahaha haha ha ok sorry
Old Oct 13, 2009 | 02:39 PM
sundevil07's Avatar
lololol ^
Old Oct 13, 2009 | 02:44 PM
FASTL61's Avatar
boredome lol
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
