has anyone...?
has anyone...?
has anyone lost power to there TCM? I get the code U0101. I checked all my fuses... replaced the TCM. and now im begining to think there is a short somewhere. car runs/idles normal. goes into R ..N.. P..and drive but when in drive it will not shift out of gear:/ also my speedo doesn't read mph but rpms still work. CEL is on and power steering is also on. thank you for your help
I'm not sure if that would work man. I think most GM PCM/TCM's are a one time thing. When a new one is installed in a car a Tech has to program the VIN into the PCM. Not sure if that applies to cobalt PCM/TCM's but if it is then thats your problem. You might have to just take it to a dealer to see if they can figure it out. Might be a hefty bill though.
if you're gonna answer the question accurate info does help, this is already a reason why css is looked down upon. nothing personal to anyone that supplied misinformation. i'm just tired of seeing a bunch of "i don't knows" until someone that does know pops up with an answer.
Well, I am fairly certain with a E37 ECU it wont work that way due to the way the computers communicate with eachother. If it works with the older pre-CanBus system then so be it, but dont be an ******* about it, we all make mistakes. We arent all mechanics or experts, Im an engineer by trade. You yourself said that the vin needs to be changed so i was not that far off.
that's why i did point out that I meant no offense. kinda hard to get across emotion in written text. i have even tried an 07 TCM on my 06 and although it did work for the most part the calibrations between the model years is different in some very key areas. we are all here to learn, right?
did the TCM need to be programmed with VIN # or was there another issue? I started throwing the U0101 code last week and have the same symptoms. I ordered a replacement TCM from a 2007 cobalt (same year as my car) with the same part # and everything.
DWoods54
Jan 18, 2014 11:36 PM
