Head Gasket
Old May 4, 2009 | 01:41 PM
Preston's Avatar
Head Gasket
So,
i believe my head gasket is blown
When i let off the gas anytime after accelerating
my car blows white smoke out pretty bad.
Whats done to my car
GT28RS60 turbo internally gated to 12 pounds
STOCK motor, STOCK clutch, no internal work(yeah i know i am pushing this motor..i am pretty sure i am over 260HP)
the exhaust smells like regualr exhaust smoke, but i am not sure what burning cooltant smells like.
think so?
Old May 4, 2009 | 01:43 PM
06black's Avatar
pure white, or blue-ish white?
coolant Vs oil.
i'd bet oil.
Old May 4, 2009 | 01:45 PM
Preston's Avatar
white
i know what burning oil smells like
my last turbo blew lol
granted i will rev my car up after school and blow some smoke out, but from what i have heard and seen from many people it is white smoke
Old May 4, 2009 | 02:08 PM
elecblue06's Avatar
coolant Vs oil.
i'd bet oil.
exactly .. annnnnddd if it was headgasket wouldnt it blow more smoke when you're on the gas lol
Old May 4, 2009 | 02:12 PM
hungryhip-ccp's Avatar
are you running coolant lines to that disco potato?
2 things...
bad turbo = puff of smoke after shift or while decel
turbo leaking coolant = white smoke during high vaccum (decel, shift)
look into your turbo, if it was your headgasket it would smoke all the time...
Old May 4, 2009 | 03:04 PM
PSHHH's Avatar
plus with a blown head gasket more then likely you would overheat and have a huge cloud of white smoke behind you...i blew mine in my mustang not fun =/
Old May 4, 2009 | 04:53 PM
hugemurph4's Avatar
agree if you blew your head gasket it would smoke all the time and if it...aghhhh i just agree with everyone on this haha check your turbo
Old May 4, 2009 | 05:12 PM
Preston's Avatar
well
i just went out for a run
and everytime i shifted, hard on gas it puffed whiteish can't really tell seeing as it is so far away.
**** you turbo, **** you
Old May 4, 2009 | 05:26 PM
elecblue06's Avatar
Originally Posted by Preston
well
me thinks you're starving the turbo of oil... look to use something else for your oil feed
Old May 4, 2009 | 05:34 PM
well
stop driving it and get a rebuild kit asap... before you need a new center section...
Old May 4, 2009 | 07:14 PM
Sw4y1313's Avatar
Did you buy the turbo from garrett brand new? There should be a year waranty no?
Old May 4, 2009 | 08:40 PM
yep!
Old May 4, 2009 | 09:49 PM
YSUsteven's Avatar
If its burning coolant, your coolant tank should be low... If its not, that not it.
Old May 10, 2009 | 03:29 PM
Preston's Avatar
anyone put in consideration piston rings.
people keep telling me that
i will explain what happens again
i will get on, any throttle, unless i really dont hit boost or high vacuum or any rpm below 2500.
WHEN I SHIFT and put it in the next gear and hit the gas, a puff of blue smoke comes out..
i am hoping not internal stuff
by the way i just got rid of the turbo my car is up on stands right now...
Old May 10, 2009 | 04:08 PM
HunterKiller89's Avatar
piston rings on the stock 2.2 are NOT made for boost. i wouldnt be suprised if you blew one (or several). check your coolant and check your oil. one of them should be low...thatll answer your question of what you're burning
Old May 10, 2009 | 04:17 PM
Preston's Avatar
my oil is already drained my coolant is kinda low...
will there be oil in my coolant? or mixed or wahtever you wanna say
Old May 10, 2009 | 04:28 PM
JimzSS's Avatar
the coolant will seperate from the oil , give it some time to settle in the drqain pan and then take a look, or pour it into a jug/container you can see into.
Old May 10, 2009 | 06:40 PM
so did you ever do a compression or leakdown test? it will answer all your questions in 20 min...
Old May 10, 2009 | 07:07 PM
randizzle's Avatar
stole the words out of my mouth. why do people like guessing so much? why not do some tests and figure out what's wrong?
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
