Header and Downpipe question
Hey guys i know this is a beat down topic, but all the threads i have seen provide answers to the 2.0 and 2.4....what are some header and downpipe options for the 2.2!?!?!? besides pacesetter because they are cheap and do not provide quality....thanks in advance guys
i hear CA is good but sometimes it might rub on a coolant line. right now my setup is the SS/SC manifold/downpipe, which works very nicely, made it sound amazing, keeps the cat, bolts right on, and cost me like 60 dollars each from members. haha. its the best bang for your buck.
sweet....let me know how it fits and if you like it...i want ones that dont require welding....what size collector for the downpipe fits 2.5" or 3"?? and are high flow cats street legal???
that would be the CA header....i ordered it a long time ago and its good quality. i sent it back cause it was hitting the coolant pipe and they are sending me the new designd header as soon as it gets in.
oh ok...soo would i need to specify that to them so i get the new design or did they fix there production all together?? also does it come in ceramic coated?? i dont want to put a header in unless its ceramic coated because of the extra heat
2005 ls coupe
"right now my setup is the SS/SC manifold/downpipe, which works very nicely, made it sound amazing, keeps the cat, bolts right on, and cost me like 60 dollars each from members. haha. its the best bang for your buck."
__________________
Do you order the SS/SC mainfold and downpipe from Gm parts???and how does that fit the 2.2??
__________________
Last edited by chevybolt88; Jun 4, 2007 at 07:46 AM. Reason: Automerged Doublepost
This is correct, get the ceramic coated header from pacesetter, they are high quality. They have improved huge in the last few years, and are the # 1 prefered header to the J-Bodies.
IMO ceramic coated is better than stainless. As the ceramic does more functions than the stainless, which just looks nice... Ceramic keeps the heat down.
i know ceramic is better, but my main problem with the pacesetter is it doesnt fit, you need to cut and weld it to get it to fit, and i have heard many people complain about leaks and throwing codes...so idk
if it doesn't fit, it's because it wasn't installed properly. it's a long tube header, so you have to cut the dowpipe.
and then weld them together right?? I just think direct bolt on would be much easier and prolly less chance of something going wrong...I have nothing against pacesetter its just the amount of negative things i have heard have outweighed the positives for the header, so it seems like i would be playing like a "wait and see game" to see whether it works out great or causes me problems
also do you go WOT a lot with the downpipe? if so how long did you wait till you did?
Personally, I'd rather buy a quality stainless header that isn't coated and then wrap it with a header wrap than to by a non-stainless coated header. CA first made a header with a 2.25" collector and now they should have a 2.8" collector header available. Other companies make headers with 2.5" or 3" collectors.
Back to the subject now. Is there any headers out there that are direct bolt on that do not require you to modify the downpipe?
2005 ls coupe
__________________
__________________
i actually ordered them from members on here. you can find people selling their stock ss stuff for cheap, but i think if you order them from GM they arent too much more expensive. they fit right on the car. the only difference is the pipes are bigger. if you take a look at the collector on the SS manifold and the LS manifold, they are way different. but yes they bolt directly on. pretty much the same engine.
see thats what i dont get if there not that different then why don't headers for the SS fit the 2.2??
"Back to the subject now. Is there any headers out there that are direct bolt on that do not require you to modify the downpipe?"
Im with you man i've been looking forever lol ^
see thats what i dont get if there not that different then why don't headers for the SS fit the 2.2??"Back to the subject now. Is there any headers out there that are direct bolt on that do not require you to modify the downpipe?"
if they do then why do all the companies say they don't??? everyone on the forum says there interchangeable, but when i call the plaaces to ask questions they say just for the SS...i just don't want to buy something and then go to put it in and it doesnt fit or something....just confuses me lol
