header wrap
Old Dec 1, 2007 | 02:28 PM
bikeboyben14's Avatar
header wrap
who has any experience with this? ive heard pros and cons to it. the good is that it helps keep heat in for exhaust scavenging and bad is that also holds moisture in to help create rust. what is you guys input on it
Old Dec 1, 2007 | 02:29 PM
joeworkstoohard's Avatar
well, on a stainless header it's not bad, but i wouldn't use it on a cast part. it'll crack the bitch
Old Dec 1, 2007 | 02:45 PM
i was thinking of using it on a zzp header with the black high temp paint on it since i cant afford the stainless pieces
Old Dec 1, 2007 | 02:48 PM
SilverBalt's Avatar
i used to race go-karts, with the 5 hp brigs engines on them, and if we wrapped a cast iron or even a steel header with the wrap after about 100 laps or so the header would literally explode, and it felt as if nitros was added to the fuel...
i would not use it unless it was on stainless and just wondering, why would u really bother with it? i see header wrapping as kinda pointless the header really is not effecting the temperatures of anything
Old Dec 1, 2007 | 02:57 PM
wow that kinda sounds dangerous so i guess im not going to wrap it. well my dad used to drag race and he said he always wrapped htem to keep some of the under hood temps down so i thought bout it for my car but if its not worth it, ill just ditch that idea. thanks guys
Old Dec 1, 2007 | 03:19 PM
redlineblueline's Avatar
send it out to get jet coated
http://www.jet-hot.com/Pages/coatings.html
Last edited by redlineblueline; Dec 1, 2007 at 03:19 PM. Reason: Automerged Doublepost
Old Dec 1, 2007 | 03:32 PM
Pacific Cobalt
Guest
Posts: n/a
Don't Do It
If ever you have a problem with the part you will likely be denied a warrenty replacement part.
Most header manufacturers like ZZP don't approve of the use of header wrap
Old Dec 1, 2007 | 03:41 PM
anthonyS88's Avatar
im going to header wrap my pacesetter header
Old Dec 1, 2007 | 03:42 PM
an0malous's Avatar
hmmmm interesting. I did not know this about headerwrap.
Old Dec 1, 2007 | 03:43 PM
i had my pacesetter on my 2.2 wrapped and i dont think it really did anything
Old Dec 1, 2007 | 03:44 PM
anthonyS88's Avatar
im just going to wrap it because i got the black one and the paint is gonna burn off and look like ass
Old Dec 1, 2007 | 03:47 PM
send it out to get coated
Old Dec 1, 2007 | 04:06 PM
anthonyS88's Avatar
too expensive
Old Dec 1, 2007 | 10:50 PM
BlackLS's Avatar
I thought about wrapping mine but I haven't gotten to it yet but when i do it i hope i have enough left over to wrap the intake as welll to keep it cooler.
Old Dec 1, 2007 | 10:57 PM
TurboTechRacing's Avatar
Dont wrap a header, get a ceramic coated header, or have yours coated, the wrap WILL "rot" the tubes.
Old Dec 2, 2007 | 02:05 AM
well i just ordered the zzp header and chose to get the dp in stainless and i guess ill just leave the black paint open no one will really see it anyways
Old Dec 2, 2007 | 11:44 AM
anthonyS88's Avatar
i dont understand what you mean by it will rot the tubes
Old Dec 2, 2007 | 12:01 PM
NJHK's Avatar
The only post in this thread that made sense.
Thank you Aaron.
Old Dec 2, 2007 | 12:02 PM
anthonyS88's Avatar
yes but why
Old Dec 2, 2007 | 12:08 PM
NJHK's Avatar
Condensation can get in between the wrap and the tubes and the wrap will hold it there longer than naturally causing a rotting over a period of time.
That will do absolutely nothing.
I'm assuming you're talking about a alluminum tube'd intake...alluminum doesn't retain heat as great as you might think.
The point of a header wrap is to keep the heat IN, not OUT. Putting it on your intake will be reversing the purpose and it still will ultimately do nothing to benefit you.
too expensive
It's not that expensive. You have to call them anyways to get a pricing, there isn't a specific set price because it depends on what you're coating.
I've dealt with Jet Hot and they were great with customer service and shipping.
Old Dec 2, 2007 | 12:13 PM
anthonyS88's Avatar
^ i know that it is good, but if i wanted that done i would have just bought the armor coated header instead of the painted one
Old Dec 2, 2007 | 12:15 PM
Thank you Aaron.
just trying to help out.
Old Dec 2, 2007 | 09:20 PM
BlackLS's Avatar
Ok thanks for letting me know. I was just thinking about doing it because i had seen a post on here about someone doing it and it kept there IAT2's down like 10-20 degress
Old Dec 2, 2007 | 09:31 PM
NJHK's Avatar
No problem
jcalvin1126
Oct 26, 2015 12:31 AM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
budah93
Sep 15, 2015 07:23 AM
