? on headers
Old Aug 20, 2008 | 11:52 AM
scotch89's Avatar
? on headers
i was going to buy the set headers and a dp high flow cat, but would i just be better off buying headers then just buying a high flow cat??
Old Aug 20, 2008 | 11:54 AM
Pickles's Avatar
I would say get both the header and downpipe, but that is just my opinion.
Red2.4SS's Avatar
The header will improve flow a lot. The high flow cat with the header would be
Old Aug 20, 2008 | 12:14 PM
burzumaske20's Avatar
uh just make your own downpipe it will cost you under 150 dollars or less.Why pay more if you don't need to.I paid for the piping 13 dollars that is it and I am catless.
Old Aug 20, 2008 | 05:27 PM
YzRider452's Avatar
I have the zzp midlength header dp combo with highflow cat. Its awesome.
Old Aug 20, 2008 | 05:30 PM
ecotecon18s's Avatar
depends on where you're looking to make power at...
IIRC
shorty header/dp-higher RPMs
midlength/dp-midrange
longtube 4-2-1~all around
Old Aug 20, 2008 | 06:51 PM
TurboTechRacing's Avatar
If you want to make max top end power, the vibrant 4-1 header is the way to go, as it also comes with a downpipe and a high flow cat, which all BOLT UP to the cat back exhaust
Old Aug 20, 2008 | 06:54 PM
Jn2's Avatar
Jn2
vibrant is the way to go, i have it on my ls and i love it, and as far as bolting right up yes it does, but it does have it flaws once mixed with a aftermarket exhaust...nothin big and nothin ima get into...
Old Aug 20, 2008 | 10:15 PM
YSUsteven's Avatar
You would be much better off buying a set of headers, then you could keep one and give the other to me.
But seriously, if you are going to go to the trouble of getting either a header or a downpipe, you might as well spend the extra $$$ and just get both. If you get them at the same time, you only have to take it apart once.
Old Aug 20, 2008 | 10:24 PM
07cobalt19's Avatar
well you get what u pay for as far as performance goes. i have the zzp mid length header/dp combo and their amazing. if i were u i would buy headers and a down pipe high flow cat
Old Aug 20, 2008 | 10:28 PM
yellowltcoupe22's Avatar
zzp mid lenght combo is the best bang for the buck imo.. thats what i have and it makes a good difference.
Old Aug 20, 2008 | 10:48 PM
Pickles's Avatar
Header(S)....??? Seriously?
And yes, the zzp combo is a great deal, but keep in mind there have been issues raised concerning the quality of the flex pipe and the connection between the header and dp...
Not saying anything AT ALL about Zoomer and his quality business, but be sure to ask questions about the product before you buy it.
Old Aug 20, 2008 | 10:50 PM
i havent heard bout the problem in the connection between the header and dp but the problem with the flex pipe has been fix. they found what the problem was and corrected it so i you get the zzp combo you shouldnt have to worry bout that part.
Old Aug 20, 2008 | 10:58 PM
pykie's Avatar
Get both, but STAY AWAY from Vibrant.
Every guy i know of around her ein Nova Scotia who has one clogged the cat bad!!!
and they do not recomend buying a vibrant cat or header.
so just be careful.
Old Aug 20, 2008 | 11:26 PM
Pickles's Avatar
Good to know. Again, I wasn't saying ANYTHING bad about them, just trying to bring to light some of the issues past. And Myself, I do have a zzp dp.
Old Aug 21, 2008 | 07:07 AM
so just be careful.
That is not vibrants fault, that is an "improper tuned" car, runing way to rich..... Get a tune and run a correct Air/Fuel Ratio and it wont happen. A/F ratios plug cats, it has been known for years....
Old Aug 21, 2008 | 11:35 AM
RyanRacer48's Avatar
Seriously dude I was in your shoes 3 weeks ago asking about headers. I didn't take the advice, bought a pace setter header for like 160 bucks shipped. Now i'm scraping on here trying to find somebody w/ the downpipe to actually hook it up . Which from exhaust depot is 215. + 125 for cat. So i could have had the badass header for almost the same price w/ no stress about hook ups.
Old Aug 21, 2008 | 01:31 PM
long tubes will always need a custom related downpipe or fabricated.In the long run it is worth it.my downpipe is not 100% completed until I get the new 02 sensor from autozone which they had to order.the other one will be spliced back in of course.
Old Aug 21, 2008 | 02:11 PM
To be honest after speaking with turbo tech racing, and Dan from clear image, the money that goes into these headers is why they are expensive. I will let you know how my pace setter works out now that I found a downpipe for it.
Hopefully it will fit . its the downpipe off a midlength zzp header. Any issues I should expect?
Old Aug 21, 2008 | 02:14 PM
say if you go with the exhaust depot route it should fit with no problems.only situation I am in now is waiting on my new 02 sensor and I am fine,and possible throw on a cat.converter,if the sound just gets way to rediculious
Old Aug 21, 2008 | 02:29 PM
bur do you know w/ the flanges welded onto the zzp downpipe if it will hook up to a pace setter header?
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
budah93
Sep 15, 2015 07:23 AM
hacadacalopolis
Sep 8, 2015 11:42 PM
