Headers/Downpipe
Old Jan 18, 2008 | 07:50 PM
MP Cobalt's Avatar
Headers/Downpipe
I just installed my GMPP Performance Exhaust. I now want to get a new set of headers and downpipe. I own a 2.2L cobalt. Which is the best headers and downpipe to install on my car. i would like anyones opinion.
ok i ask nicely for peoples opinions, and all i get is nothing. Your opinions and good websites would be very great.
Old Jan 18, 2008 | 07:59 PM
XM15's Avatar
lol Easy man. The 2.2 section doesn't exactly jump with activity.
The big question is, where do you want your powerband? The type of header will determine where it is to some degree.
Old Jan 18, 2008 | 08:39 PM
YSUsteven's Avatar
I want low end torque, which one would be best for that?
Old Jan 18, 2008 | 09:10 PM
XM15's Avatar
Longtube header. I have the Vibrant setup and like it alot. I'm not sure who else offers a longtube header though.
Old Jan 19, 2008 | 05:14 PM
MP Cobalt's Avatar
so the vibrant will give me more low end torque. Do you have both vibrant headers and a downpipe? What site did you order this off of so i can look around. Im gonna swap my intake manifold next then look for headers and a downpipe
Old Jan 19, 2008 | 05:19 PM
ecotecon18s's Avatar
I have the CA header and Catless XTC downpipe and it def. opened up the top end more...no more lag between 80-100 like there used to be...
Old Jan 19, 2008 | 05:43 PM
MP Cobalt's Avatar
how much did your headers and downpipe cost ?
Old Jan 19, 2008 | 05:44 PM
yellowltcoupe22's Avatar
runnin without a cat dont effect your the way your car runs..? i figured it would make it run like **** with out a cat.. we must not have a o2 sensor after the cat..
Old Jan 19, 2008 | 06:08 PM
RBC's Avatar
RBC
Don't waste your money on 2 headers, you only need one header unless you got some kind of option that the rest of us were never offered.
Old Jan 19, 2008 | 06:21 PM
I got both the header and DP used, so they were pretty cheap. The Header was 130 shipped and the DP was 131 shipped, then the various gaskets were about 30 total. I bought the ARK CEL eliminator for the DP, and so far it has worked, but fitment for it sucked; we had to air hammer parts of the metal under the car to get it to work.
Old Jan 20, 2008 | 02:50 PM
cougar2588's Avatar
i've never heard of one of those. i tried searching for it but i couldnt find it. where did u pick that up from?
Old Jan 20, 2008 | 03:09 PM
YSUsteven's Avatar
The top end was better, but what about the low end torque? (under 3000) Did you notice any improvement down low?
Old Jan 28, 2008 | 09:51 PM
t800's Avatar
This is something I have also been curious about. Which headers produce the best low to mid range power. I know mostly everything improves either the high end or low end. Whats in the middle ???
Old Jan 28, 2008 | 10:08 PM
XM15's Avatar
Long tube and mid length headers. Check out Vibrant and ZZP. I think Clear Image has a group buy on their header right now as well.
Personally, I would open up the exhaust first.
With regards to the Vibrant setup, because it is a longtube, it won't bolt up to the stock downpipe. They sell the header and DP together, which will bolt right up to the cat back.
Old Jan 28, 2008 | 10:19 PM
t800's Avatar
I think I will go with the ZZP thanks guys !!
Old Jan 29, 2008 | 02:39 PM
CARLYLE's Avatar
hate to bust your bubble but headers especially longtubes wont give you any low end power headers are a higher rpm performance piece. and the closest you can get to low end power would be shorty headers
Old Jan 29, 2008 | 07:06 PM
YSUsteven's Avatar
So if a shorty header is better for low end torque, does that mean that the GMPP maniflod is even better than a header due to its extremely short 4 to 2 section?
Old Jan 29, 2008 | 07:12 PM
XM15's Avatar
My bubble is just fine. Here is part of a tech article from an exhaust design company:
"When considering a header design, the following points need to be considered:
1) Header primary pipe diameter (also whether constant size or stepped pipes).
2) Primary pipe overall length.
3) Collector package including the number of pipes per collector and the outlet sizing.
4) Megaphone/tailpipe package.
There are many ideas about header pipe sizing. Usually the primary pipe sizing is related to exhaust valve and port size. Header pipe length is dependent on wave tuning (or lack of it). Typically, longer pipes tune for lower r.p.m. power and the shorter pipes favor high r.p.m. power. The collector package is dependent on the number of cylinders, the engine configuration (V-8, inline 6, etc.), firing order and the basic design objectives (interference or independence). The collector outlet size is determined by primary pipe size and exhaust cam timing. "
Don't bother with the GMPP manifold. Get a true header.
XM15's Avatar
Old Jan 29, 2008 | 08:34 PM
hubes's Avatar
I think the vibrant would be too big for a 2.2, especially if you want low end torque, as the primaries are 1.75
05vue-redline-06ion
Tuning
May 14, 2011 02:01 PM
Melon
May 12, 2011 05:47 AM
ryank771
Jun 10, 2010 01:33 PM
laxoalie609
Feb 24, 2009 07:41 PM
