Help! C.E.L. P107
Old Apr 19, 2012 | 09:02 PM
lilnev11's Avatar
Help! C.E.L. P107
Okay got a CEL on code comes up as bank 1 P107 which is the o2 sensor correct? If i toss a new one in there and erase the code is it gonna fix my head ache? Or ive also read it to be a map sensor as well throwing the whole ecm outta wack.
Any help is greatly apreciated!
Old Apr 19, 2012 | 09:08 PM
05Slowline's Avatar
p0107?
map sensor. clean it first see if it stops if not replace.
Old Apr 19, 2012 | 09:15 PM
lilnev11's Avatar
Im almost positive it was just p107 i mat be wrong ill test it again. but would the map sensor reading say bank1 ? or is that just simply referring to it being upstream from the exhaust?
Old Apr 19, 2012 | 09:20 PM
05Slowline's Avatar
there is no p107 code is why i ask....maybe P0170? Fuel Trim Malfunction (Bank 1).
Old Apr 19, 2012 | 09:29 PM
lilnev11's Avatar
It said system too lean, sorry i probably shouldve added that. but i'll check and clean the map. any technique to cleaning it?
Old Apr 19, 2012 | 09:32 PM
05Slowline's Avatar
if it's the code i posted last you'll want to clean your maf and do you have an air intake or something
Old Apr 19, 2012 | 09:35 PM
lilnev11's Avatar
Nope its the stock housing but i did take that big snorkel out from the fender well to free up some air if you know what im talking about. and i bought a K&N stock filter for it but that was purchased after.
Old Apr 19, 2012 | 09:37 PM
lilnev11's Avatar
not too long after it had come on it started to run a little goofy too. It's a manual and when i release the throttle in gear or in neutral the rpm jumps up a little then falls down like the throttle body isnt closing right away.
Old Apr 19, 2012 | 09:40 PM
05Slowline's Avatar
id clean the maf first, prob has k&n oil on it, if that doesn't work, put the stock back in and see if problem persists. wipe the k&n with some paper towels also lol.
Old Apr 19, 2012 | 09:47 PM
lilnev11's Avatar
the light was on before i put the K&N in though. what that cause it to run lean? i guess if that sensor's clogged up it would make sense to think there isnt the proper ratio of air.
Old Apr 19, 2012 | 09:48 PM
05Slowline's Avatar
if it's dirty the reading can get skewed etc hit it with some cleaner and let it dry an hour
Old Apr 19, 2012 | 09:55 PM
DBlock's Avatar
QUEEF-NUGGETS
Good boy
Old Apr 19, 2012 | 09:56 PM
lilnev11's Avatar
this may be a stupid question but i have to ask it.. what type of cleaner? I have some stuff at work that we use for fuel system cleanings that just gets rid of all the carbon build up. The stuff we use for the throttle body is in a spray can. So just spray some of that stuff on the MAF (off of the hose obviously) reset the code see if it comes back, If it does do the same to the MAP?
Old Apr 19, 2012 | 09:59 PM
05Slowline's Avatar
Amazon.com: CRC 05110 Mass Air Flow Sensor Cleaner - 11 Wt Oz.: Automotive
should have it at your local autozone, advanced, napa etc.
find out what the real code is first too lol, like i said p107 isn't a code and it COULD be either of the ones i listed so get the right info first then troubleshoot.
Old Apr 20, 2012 | 11:19 AM
lilnev11's Avatar
Im a *******, it is a p1107 i just misread it all three times i tested it.. but im going to try cleaning them today then see how that turns out
Old Apr 22, 2012 | 03:27 PM
lilnev11's Avatar
Double checked it again today at work. came up as a P0171 (system too lean, bank 1) went and bought a new MAF and it came right back on! this is annoying lol. SOMEONE HELP!
Old Apr 22, 2012 | 04:15 PM
05Slowline's Avatar
stock intake and stuff right?? make sure theres no leaks post maf..
Old Apr 22, 2012 | 11:06 PM
lilnev11's Avatar
yeah stock for right now. i may be buying a new intake just because all those plastics are ugly as hell. but ive searched up and down the damn thing and couldnt find any type of leak.
Old Apr 26, 2012 | 11:57 PM
scagnetti76's Avatar
Have you done a vacuum test?
Old Apr 27, 2012 | 11:21 AM
CobaltItaliano's Avatar
Did you unhook the negative battery cable and let it sit for a good half hour? Sometimes it just takes a while for the computer to reset itself.
Old Aug 10, 2012 | 04:10 PM
SS1's Avatar
SS1
can we bring this thread up again cause ive been having this problem for years now and i still cant figure it out.
Old Aug 10, 2012 | 04:12 PM
SS1's Avatar
SS1
bank one too lean code. keep burning through cats. car is an 06 ss/sc same issue with stock airbox and cai. the computer was flashed as an 05 by the dealership and the problem went away but then the fuel guage didnt work so i had them flash it back and immediately the code came back and within a few weeks i burned out another cat and an upstream o2 sensor. i need some help on this one bad guys.
Dexter
Oct 1, 2013 08:35 PM
Kolt
May 7, 2009 12:37 AM
jacobmprater
May 5, 2008 10:02 AM
