need some help getting ready to build for moar boost ..
alright guys, in about 2 weeks (i hope) i'll be buying a spare engine for the cobalt. i wanna build it. this is the first car im building. what compression should i go with and such? head work? oem stuff? opinions. looking to be in the 350-400 range is what im shooting for. right now i have a k04 turbo.. may swap that for a s256. feel free to post opinions and pics! thanks!
8:9:1 compression, ported head. you have to machine the head to fit supertech springs but the ZZP springs fit as a direct replacement and will eliminate valve float, new rod and main bearings, neutral balance shafts optional, new timing chain kit is always a good idea, new timing chain tensioner couldnt hurt either, 80# injectors, bigger fuel pump, stuff like dat.
stock compression and darton sleeves would be real proper and overkill. might as well spin the **** out it after that but thats a whole new can of worms. for 350hp don't drop the compression if you're sticking with the k04, look at the lnf crowd. the s256 is damn nice but there are better options if you're building your own kit. either way, i'm saying, keep stock compression.
Since you are gonna have another motor and therefore no down time while building, do everything you can. Rods, pistons, bearings, valve springs and retainers, balance shafts, p&p the head, you could do cams but not really necessary on a daily driver. And arp head studs to hold everything down.
I got a fully built motor for sale if you interested.
Wiseico pistons10:1 .20 overbore
Bates sleeves
Eagle rods
Neutral balance shafts
Bates hardened oil pump gears
Arp head studs
Supertech dual spring kit with inconel exhaust valves
Ported head
Stage two comp cams.
Bates sleeves
Eagle rods
Arp head studs
Ported head
Didn't you just finally get that back on the road a couple months ago? Why you selling after all the work you did?
