Help Guide a 2.2
Help Guide a 2.2
Well here's the deal..I wanna build up my balt for more power. The only problem is is that my rods/pistons are only rated to 250hp. I dont know much about internals. Can someone help guide me on which is best to buy and what exactly I need to do this? thanks
I'm going with this piston n rods, also I suggest getting ARP head studs from turbo tech racing
yeah i just realized that lol....u really need to build these engines to make more power there not made for much but can be done. i on the other hand will only do so much since its my dd
I'm doing mine once all the parts get here. just a mild build tho. Got the rods and pistons from that link above(email them and you can get them for 750 shipped), arp headstuds from ttr, gonna get some valve springs from zzp and then i got a new head gasket, rod and main bearings, and valve cover gasket kit from the dealer in town. I'll be doing it myself with a buddy. Just go by the build book and torque everything right.
im thinking about going all motor. running higher compresion. i know nothing about building motors. im going to take mine somewhere to get done. i just need help on what parts to order lol
glowbalt i have the 2.2 build book saved on my labtop if you want i can send it to you. pm me your email address. it's for 250 to 400 hp and then it also has 400 to 600 hp on there
If your building a roots style supercharged motor I would never dip below the factory compression. It's part of the reason the 2.2 makes so much torque with the M62. You will you gain more power probably not but reliabilty yes. Dropping compression will actually cause you to lose torque and possibly horsepower.
1. our heads flow like ass and not even too great when ported and polished even though its a huge increase.
2. u will spend a lot of money for minimal gains.
3. depending on wat compression u go..anything over 12:1 really it wouldnt be very wise to run pump gas even if its 93. U would probly need a mix of race gas and 93 at a bare minimum
4. if u wanna go NA plz get a v8 u will thank me afterwards
But i know that u know wat ur talking about just from ur other posts
u will need a tune for just the air and fuel mods...if u added stock compression pistons and rods a tune is not needed...if u change injectors or a throttle body or something like that is when the tune is really needed
the link is for 10.1 compression and rods for a 2.2 so if u put those in no tune is needed. if u did these engine internals are u gonna still use the m62 blower?
a parts list u would NEED is rods, pistons, rod beaings, main, bearings, arp headstuds, and a new head gasket at the minimum.
I have a trifecta tune already. lol...but I was just wondering if I would need a change in the tune for the RODS/PISTONS...But you say no so its a good thing..I dont plan on going over 350 anyways
