--help with oil pressure install--
Old Jan 26, 2007 | 06:46 PM
exiged's Avatar
I have a mechanical gauge and im just trying to figure out where to install the sender....
i have a 2.2 by the way
this is kinda the angle im looking at....
thats what my sender looks like.....
and i saw in another how-to the guy put his (I think) where this bolt is (under the red clip thing... sorry i dont have a drawing program or ide circle it)
Is that where its supposed to go??
if i had to guess i would think it would be down closer to the intake manifold!
Old Jan 26, 2007 | 07:58 PM
Dustin's Avatar
Stole my name. :x
Old Jan 26, 2007 | 09:03 PM
exiged's Avatar
haha....its cuz im saving to buy an exige...
someone must know.....
bump!
Old Jan 27, 2007 | 01:44 PM
SKDR112888's Avatar
Icnat find it either, I have a 2.0 and Im trying to do this today,
Old Jan 27, 2007 | 06:46 PM
Halfcent's Avatar
I'm old school
As shown above, Any of the 4 plugs highlighted are oil pressure. The only one that isn't is the lower right plug, thats coolant.
Oil is supplied to the head through a restrictor, shown in the second picture.
You will need the proper size hex key and big pair of plyers. Don't hammer the key, just use the plyers and keep pulling harder and smoothly until it pops loose. It is SUPER tight.
Old Jan 27, 2007 | 06:59 PM
Boosted_SS's Avatar
OK this has my interest i have this same kinda gauge so this has my interest!i've been putting off doing this cause it looks like such a bitch! what side of the head are we looking at here? do we have to take the head off and remove that restrictor to install this in those plugs?
Old Jan 27, 2007 | 07:07 PM
Halfcent's Avatar
I'm old school
This is the trans side of the engine. You do not have to remove the head. You don't have to remove much of anything really. Only what you need to reach the plugs. You do not need, or want, to remove the restrictor. The pressure and temperature will be the same. It only reduces the flow.
Old Jan 27, 2007 | 07:20 PM
Boosted_SS's Avatar
ok so this is the passenger side of the head correct?
Old Jan 27, 2007 | 09:09 PM
Halfcent's Avatar
I'm old school
No. The transmission side. Look at the pictures above, then go open your hood.
Old Jan 28, 2007 | 12:14 AM
Boosted_SS's Avatar
sorry chief i ment to say drivers side
Old Jan 28, 2007 | 10:59 AM
biniecki's Avatar
where is everyone getting their gauges at. I am looking to install oil pressure and water temp.
Halfcent for water temp could i remove the coolant plug or is there an easier way to do that.
Old Jan 28, 2007 | 11:17 AM
Halfcent's Avatar
I'm old school
It would depend on the sending unit that comes with the gauge. I don't believe water temp senders install there.
Old Jan 28, 2007 | 11:42 AM
joeworkstoohard's Avatar
for future ref, the "front" of the engine is where the belts are and the "back" or "trans" side of the engine is the other end of the crank where the transmission attaches. this is true independent and the engines layout on the car.
for example, in a vw where the engine is in theback, the belt is all the way back. stil the front of the engine.
.side issue, anyone done one in a 2.4? I am assuming that it is the same??
Last edited by joeworkstoohard; Jan 28, 2007 at 11:42 AM. Reason: Automerged Doublepost
Old Jan 28, 2007 | 11:43 AM
Boosted_SS's Avatar
here ya do bro straight off autometer's website...
The installation information presented below is based upon the experience and discovery of Auto Meter Products research and development. Information is added to this database on a monthly basis as we are able to research new vehicles and better installation methods as they become available. Please use this information to aid in your installation. If you do not see your vehicle listed or your model varies from the information provided please visit our forums, use the Ask us a Question page, or call our tech support group at (815) 899-0801.
Oil Pressure Gauge Thread Size for 2.0 SC engine(s)
M12 x 1.75 , Use a # 2278, Oil gallery located on back of block behind large water pipe
Water Temp Location and/or Thread Sizefor 2.0 SC engine(s)
Remove plug at bottom of water pump. Use a 12mm x 1.5 Auto Meter #2277 adapter. If using a short sweep electric temp gauge (uses a single wire sender), then you must use a #2259 sender. If using a full sweep electric gauge (with a 2-wire sender), the included sender with the gauge will work. Sorry, no adapters available for the mechanical gauges.
Old Jan 28, 2007 | 12:10 PM
biniecki's Avatar
only problem is that information is for the 2.0 not the 2.2
Old Jan 28, 2007 | 12:51 PM
Boosted_SS's Avatar
that information should hold true for either the motors in that respect should hold true as far as that goes either way
Old Jan 28, 2007 | 12:58 PM
Witt's Avatar
Wouldn't using the one on the head show a lower pressure because of that restrictor?
The autometer instructions I think use the same one that the Garrett Turbo manual uses.
mkulrey13's Avatar
i have a c2 short sweet water temp gauge and i beleive that is where you isntall the sender for it. as it uses teh same adapter as my oil pressure gauge used to screw into teh head. i will attempt it when i return home in march.
Old Jan 28, 2007 | 02:18 PM
exiged's Avatar
thanks for the help man
Old Jan 28, 2007 | 09:20 PM
SKDR112888's Avatar
ok, I have a 2.0 and looks for those pluigs and CAN NOT FIND THEM!!! lol
more than likely its my mistake but I cant find the plugs you all are talking about,
Old Jan 29, 2007 | 01:03 AM
HunterKiller89's Avatar
the directions are for a 2.2
Old Jan 29, 2007 | 01:08 AM
Halfcent's Avatar
I'm old school
I would think the same thing as well. I have not seen the installation instructions for the sender. I know people have mounted senders in the head location, but I don't know if was a pressure or temp sender. That would be a fine location for a temp sender.
Old Jan 29, 2007 | 08:50 AM
SKDR112888's Avatar
yes but everyone has told me it will work for them all,
it that case, does anyone know for the 2.0?
Old Jan 29, 2007 | 08:29 PM
Boosted_SS's Avatar
what i posted was on autometers website and i can tell you there is tons of pressure when you remove those plugs behind the coolant pipe behind th motor.
Old Jan 29, 2007 | 09:14 PM
Halfcent's Avatar
I'm old school
There a large number of galley plugs all over the Ecotec block. I bet any one of them would work. I just looked at the block I have, I counted 5 plugs on one side alone.
