HELP!!!What Parts for a Engine Build
Old Mar 31, 2011 | 02:04 PM
e-bone505's Avatar
What parts are needed for an engine build so i can go turbo or super....if someone dont mind can ya list the parts and brands so i can get them
Thanks,eric
Old Mar 31, 2011 | 02:21 PM
CobaltLs505's Avatar
Pistons and rods limit is 250hp after that u need to get forged pistons and rods, turbo tech sells them
Old Mar 31, 2011 | 03:26 PM
e-bone505's Avatar
will they fit...cause i think they only fit the ss models...or are they interchangable
Old Mar 31, 2011 | 03:27 PM
alleycat58's Avatar
They sell them in different compression ratios......
Old Mar 31, 2011 | 03:47 PM
e-bone505's Avatar
which one will fit the Ls model...or can i get the same ones as the ss
Old Mar 31, 2011 | 03:51 PM
Here you go
Wiseco Forged Pistons Cavalier/Sunfire 2002-05 Ion 2004-10 Cobalt 2005-10 2.2L Ecotec - Engine Internals - Turbo Tech Racing, LLC
Old Mar 31, 2011 | 04:03 PM
e-bone505's Avatar
what bore and compression ratio should i select
Old Mar 31, 2011 | 04:19 PM
TurboTechRacing's Avatar
Most get stock bore, and just hone the cylinder.
8.9:1 if you are going to turbo/supercharge
10:1 if you plan to run all motor
Old Mar 31, 2011 | 09:32 PM
lwpmoon's Avatar
Turbo 10:1 FTW!!! (E-85 required lol)
Old Mar 31, 2011 | 09:39 PM
This can be done
Old Mar 31, 2011 | 09:46 PM
conerboner's Avatar
yeah and some patience if you're gonna do it yourself lol
Old Mar 31, 2011 | 11:05 PM
e-bone505's Avatar
is it hard to install
Old Apr 1, 2011 | 10:06 AM
HyperMuffin's Avatar
Easiest way is to pull the motor. If not it might be possible to drop the oil pan and unbolt the rods from the crank. Don't quote me on that as I am not sure it can be done that way. Either way the oil pan is coming off and you're head is coming off.
Old Apr 1, 2011 | 10:46 AM
conerboner's Avatar
you can do it with the motor in the car but it's easier to do on an engine stand. and you're going to want a new clutch if you're a manual so you might as well pull the motor. I just did mine and I've never done anything like this but i've been around cars forever my dad has an exhaust shop and does auto repair as well. I did a LOT of researching before I took the motor out.
GMTunerSource.com - ECOtec Build Book - Sport Compact Build Book
GMTunerSource.com - LSJ Build Book - LSJ Build Book
I would start there before you buy any parts.
Old Apr 1, 2011 | 10:52 AM
redcobalt07's Avatar
Yeah OP you got some work to do. You will have to pull the motor, rods, pistons, head studs, head gasket, rod and crank bearings, front and rear main seals, valve cover seals. Then you can just get a kit for the turbo or supercharger to make it simple. If you are manual you will need a new clutch. You are also gonna need some machine work for the crank after you put in new rods. Your looking close to around $5000 for all this.
Old Apr 1, 2011 | 07:48 PM
06_cobalt's Avatar
Not to thread jack but I was looking at the build book and if I'm looking for 250 to 275 whp I only need the pistons and rods? And should I upgrade the valves and/or springs as well? Even though it's really not needed.
Old Apr 1, 2011 | 07:52 PM
You will at least need rods and pistons. The valve stuff isn't required at that point unless you raise your rev limiter.
Old Apr 1, 2011 | 07:56 PM
06_cobalt's Avatar
Yea I saw that the pistons and rods were needed just curious about the valvetrain. And would raising the rev limiter to 7000 require the valvetrain parts?
Old Apr 1, 2011 | 08:00 PM
Yes
Old Apr 1, 2011 | 09:04 PM
06_cobalt's Avatar
Yes
Gotcha. thanks for the help.
Old Apr 2, 2011 | 08:48 AM
conerboner's Avatar
for 7000 all you would need is some zzp 78# valve springs.
metroplex
Sep 27, 2015 07:48 AM
soaxin
Sep 26, 2015 08:41 PM
soaxin
Sep 26, 2015 08:39 PM
