How Much???
If you put on the 2.4 intake manifold you can probably push up to 10psi but i would go no higher. If you go to 10psi you will still have a fun car so dont risk it and go higher cause once one thing goes on these cars it seems like everything else wants togo
if you don't have a spot on tune you could blow your motor on 200whp (which shouldn't be an issue since 07's now have LS2 Edit to tune)...if your tune is on you should be able to run 250whp with no problems.
Cavi guys have gone closer to 300whp on a stock bottom end, its really all in the tune.
