I/C Pump Wiring
Old Jul 18, 2012 | 08:21 PM
08baltls's Avatar
I/C Pump Wiring
Anyone have a diagram of wiring an I/C pump in an L61? I'm sure I'll have to do a relay, but I need to know how to wire it up.
I searched and didnt really find anything.
Old Jul 18, 2012 | 09:05 PM
tru2nrtt777's Avatar
Wire it into one of your accessory fuses that come on when the car comes on like the wipers and run a slightly larger fuse.
Old Jul 18, 2012 | 09:25 PM
evofire's Avatar
Tap into the power wire from the fuel pump relay. That way when the fuel pump is on, the I/C pump is on aswell. Thats how mien is.
Old Jul 18, 2012 | 09:31 PM
08baltls's Avatar
So do I need a relay?
Old Jul 18, 2012 | 10:00 PM
I honestly don't know about that, I don't know what the current is on the i/c pump.
Old Jul 18, 2012 | 10:11 PM
nhanson's Avatar
no relay needed. Just use add-a-circuit.
Old Jul 18, 2012 | 10:29 PM
evofire's Avatar
use a relay and wire it to the fuel pump relay. will protect both circuits, and will only draw what it needs, easier to diagnose if something goes wrong too. and this way when your fuel pump is going your IC pump will be too. add-a-circuits are janky IMO
Old Jul 18, 2012 | 10:57 PM
08baltls's Avatar
Do you happen to have anything with what pins on the relay go to what? Cause I suck at figuring out how to wire relays without said information.
Old Jul 18, 2012 | 11:30 PM
evofire's Avatar
haha no, my dad did it!
Old Jul 18, 2012 | 11:35 PM
08baltls's Avatar
Haha. Well I think I found a diagram that I can use to wire the relay. Now I just gotta figure out which wire is for the fuel pump and where to tap into it at.
Old Jul 18, 2012 | 11:38 PM
dtabbs's Avatar
Everything you want to know about wiring a relay.
Old Jul 19, 2012 | 12:35 AM
AzraelRaezier's Avatar
all i did was use an add a circut and tap into the headlight driving lights. so as long as my headlights were on the ic pump was running. alwys just flipped my lights on before i went driving.
Old Jul 19, 2012 | 08:58 AM
taerae86's Avatar
mine is with the fuel pump as well...you can use an add a fuse to the fuel pump fuse in your fuse box and with a relay. thats how mine is. different people have done it differently, obviously lol but i wouldnt do it without a relay, no matter what you hook it into...problem with not using a relay is it's possible you'll sometimes throw a CEL...
i have a diagram at home i can pm you if you need it...
Old Jul 19, 2012 | 12:39 PM
nhanson's Avatar
add a circuit is just fine to use.
Old Jul 19, 2012 | 03:05 PM
08baltls's Avatar
Yeah that diagram would be awesome!!
Old Jul 20, 2012 | 12:08 PM
klotzy_550's Avatar
Be carefull when you wire it in, personally I would do it with a relay because then you get zero feed back from the pump back into your ignition switch. When I wired mine in I used ZZP's instructions of using the abs switched wire for power and it had feedback which caused the car to pause before shutting down, after the key was turned off, and in the that moment it was a low enough voltage to cause the system to pull a P1682 code which is a low/high voltage in the the ignition circuit. I used the same abs wire and added a Relay and I havn't had the code pulled at all and the car shuts down immediately after the key is turned off. I did this three days ago.
See my thread on it:
https://www.cobaltss.net/forums/prob...-p0575-282871/
Old Jul 20, 2012 | 04:59 PM
taerae86's Avatar
pm'd!
Old Jul 20, 2012 | 09:35 PM
08baltls's Avatar
Thanks alot for the diagram. Thats exactly what I was looking for.
Old Jul 22, 2012 | 02:31 PM
taerae86's Avatar
No prob!
Old Jul 22, 2012 | 02:34 PM
zerosk8ter83's Avatar
i tapped mine into the drl fuse and added a switch
DarrenGC
Dec 24, 2021 01:55 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
jmelton327
Sep 26, 2015 10:04 PM
