I Need Advice on Removing A Engine
Old Jul 10, 2008 | 10:07 AM
Chambers's Avatar
I need some advice on removing the engine, after unbolting all the obvious engine mounts and disconnecting the harnesses, what is the best route to do this, should I take the engine out from the top, or should I raise the car up around the engine and then slide the engine out?
Thanks.
Old Jul 10, 2008 | 10:08 AM
joeworkstoohard's Avatar
i'd just lower it out and slide the car off, but that's mainly because my garage isn't really large enough to lift it over and out.
Old Jul 10, 2008 | 10:09 AM
Altiery54's Avatar
ya drop it out the bottom man
Old Jul 10, 2008 | 10:12 AM
Brian MP5T's Avatar
Down
Old Jul 10, 2008 | 12:08 PM
Chambers's Avatar
Ok, thanks, that will deffinatly quicken the removal!
Old Jul 10, 2008 | 06:46 PM
D4u2s0t's Avatar
Originally Posted by 2005ChevroletCobalt
get a cherry picker and rtfm (read the ******* manual)
yea... i'm pretty sure the manual doesn't say anything about taking out the engine.
Old Jul 10, 2008 | 07:05 PM
tru2nrtt777's Avatar
Is there a chiltons for the balt?
Old Jul 10, 2008 | 07:06 PM
XM15's Avatar
Yeah, I've got one.
Old Jul 10, 2008 | 07:07 PM
Nice, I'll have to order one...
Old Jul 11, 2008 | 12:05 AM
madmark's Avatar
i went threw the top, just make sure you pull the harmonic balancer off first and it slides out pretty easy
Old Jul 11, 2008 | 12:13 AM
Tazmanian_Dvl's Avatar
I would support the subframe and then unbolt it and then raise the car up and pull it out if you have the ability to get the car up in the air high enough otherwise it's through the top FTW...
Old Jul 11, 2008 | 03:54 PM
xtreme 2's Avatar
Due to space issues I've always removed the crossmember and dropped the motor out the bottom... but if you have the space a cherry picker is definitely easier...
Old Jul 12, 2008 | 04:37 PM
Chambers's Avatar
Thanks for all your replies, I have the space to pull the engine up but I think I will be taking the engine out from the bottom.
Thanks again.
HEATON
Oct 16, 2015 07:21 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
