installing intake, remapping ???
Old Aug 7, 2008 | 10:14 PM
wbrevels's Avatar
I remember readin that after you put an intake in (i think) you should disconnect the negative wire from your battery and then reconnect it and start it and the car will automatically adjust to the filter... or something like that, would like to know because i installed an intake and didn't do any of this
true or BS?
Old Aug 7, 2008 | 10:16 PM
Witt's Avatar
It adjusts either way. Unplugging the battery doesn't accelerate the computer's learning of its airflow sensor corrections.
Old Aug 7, 2008 | 10:18 PM
wbrevels's Avatar
maybe it resets it, but honestly i have no idea.. not going to wrroy about it... thanks
Old Aug 8, 2008 | 06:19 AM
Jn2's Avatar
Jn2
they suggest disconnecting whenever working with anything elecrical...
Old Aug 8, 2008 | 07:42 AM
MP81's Avatar
Which, generally, is all types of engine work.
Usually you have to unplug something.
Old Aug 8, 2008 | 10:55 AM
wbrevels's Avatar
do you know the theory behind the disconnect or is it just safety and liabllity issues?
Old Aug 10, 2008 | 12:16 PM
cobaltracrtc's Avatar
its really about safety cuz you really dont want to short out anything that your working on and the dealer wont help you. second of all the car is smart but were really smarter becuase it will learn when you put new parts in that change the fuel map but be careful becuase your map sensor might get ruined and have the dealer ship tell you that they wont cover it since its a performance part that caused the malfunction trust me
Old Aug 10, 2008 | 02:22 PM
Red07SSNA's Avatar
It is about safety, but the ECM on the Cobalt learns as you drive. If you change something it will relearn your driving habits over time. You can speed this up by erasing the DTCs (even if there aren't any) so that the learn values start at the baseline. Disconnecting the battery doesn't do this because the ECM supposedly has an internal power supply. Even the factory service manual states to erase the DTCs -- but it doesn't state to do it by disconnecting the battery.
Old Aug 10, 2008 | 04:26 PM
wbrevels's Avatar
yea NAPA sells somehting for that, also if your CEL light is on it can tkae that away, runs about $80 but it's chepaer then going to the shop
DarrenGC
Dec 24, 2021 01:55 PM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
OrangeCoba
Sep 25, 2015 06:06 PM
