installing zzp 2.5 in downpipe, help a newbie
So i just got my downpipe earlier this week and am looking to install it over the weekend. Im going to bolt it up to the stock manifold, which appears to have corroded studs, and on the bottom to my option/tsudo catback. i have the gaskets i need, but i have not done anything like this before, anybody have any tips for a newbie? what tools i need, and how much time will this take me?
your going to need a ton of patience to break those three bolts loose where it connects to the manifold.. thats my best advice other than that its pretty much self explanatory and simple
I did my buddies dp on his 2.2 and it took a bunch of patience, a torch, some sore hands, and an hour of our lives to figure out how to get those bolts loose.. hopefully you have better luck than we did!
Not sure about that. But I know when I did my buddies full exhaust we just heated the bolts up red hot and used vice grips to bust em loose. Came off simple after half a can of pb blaster didnt work
well im borrowing a blowtorch from work, i got some pb at home, just picked up an o2 sensor socket..... id sayy im just about good to go cause the rest is just basic tools right?
Does your blowtorch have oxyacetelyne (spelling?) and oxygen or is it just a propane torch, because if its just a propane torch its probably not going to get hot enough. I've done alot of exhausts and without an actual torch the bolts just snap or the nuts strip.
I've found penetrating fluids to just be a waste of money on exhaust parts because without heat nothing comes apart unless its a year old or newer
