jet maf sensor is awsome
so i have a gmpp air intake 2.4L intake manifold and i have a 2.4l tb. i have no issue with the first 2 items (intake, manifold) i had the tb sitting around so i installed it and fell right into limp mode as expected so i took it off well in the process i ruined my stock maf and was throwing codes so instead of buying the stock one i said what the hell and i bought a jet performance one........
worked great so i also said what the hell and istalled the tb again and WOW no limp mode and the car runs great
i would recomend this to anyone who wants a 2.4l tb on ther 2.2L
i have an 07 g5 and i have had this setup running for 3 months with no problem
One more question is the wiring the same like is it just plug and play or did you have to rewire the TB?
On another note could you please tell me is the wiring the same for the 2.2 and 2.4 TB? I want to know if its just plug in and go or if you have to mess with the wiring for it.
Also one last thing if all this is true this would be a cheaper route then having to get trifecta tuned for your 2.2. No offense to anyone who has used trifecta or trifecta themselves Ive never heard anything bad about them and I m not trying to bash the company its just this way would be cheaper $136 compared to $250
I just tried looking up here www.auotanything.com that's where I purchased mine and it was for $134.95 and shipping was free. However, I just tried to find it through them and they don't sell it anymore
When I purchased mine they were available for both 2.2 and 2.4 but not for the 2.0. What it is is a reflashed stock unit used to recalibrate the ecu what people call a canned tune. All you do is use a phillips to take out your old MAF and put this new one in.
Sorry for all the Dumb questions but I'm about to start doing work for more HP/T and this is my first time.
i work at bumper to bumper and i get all my parts at cost.. as for the maf for the 2.4L i have no idea
you know what i can't remember if the wiring was the same or not for the tb on the 2.4 vs 2.2 i have an 07 i thought it was a plug and play but i cant remember from my setup
pn is 69125 for 2.2 i dont know if its the same for the 2.4 i can check though
confirmed the 2.2l will work for the 2.4l
those maf wires do not have the power to reprogram anything!!! you really think that thru a 5 wires u can get to the ECM and change everything??? u really think that is possible??? u have a OBD2 port that has loads more wires, that leads to many other, that lead to the ECM, its has the power to get into the ECM and pull reading out and codes etc, your MAF wires do not
