jet maf sensor is awsome
Old May 12, 2009 | 03:11 PM
iflyg5's Avatar
so i have a gmpp air intake 2.4L intake manifold and i have a 2.4l tb. i have no issue with the first 2 items (intake, manifold) i had the tb sitting around so i installed it and fell right into limp mode as expected so i took it off well in the process i ruined my stock maf and was throwing codes so instead of buying the stock one i said what the hell and i bought a jet performance one........
worked great so i also said what the hell and istalled the tb again and WOW no limp mode and the car runs great
i would recomend this to anyone who wants a 2.4l tb on ther 2.2L
i have an 07 g5 and i have had this setup running for 3 months with no problem
Old May 14, 2009 | 01:26 PM
1niceLS's Avatar
So let me get this straight (and yes I read the whole thing) all you did was install the Jet Performance MAF and were able to run the 2.4 TB with no issues what so ever? If thats the case I m going to the junk yard asap because I already have the Jet Performance MAF installed and was thinking I would have to get tuned.
One more question is the wiring the same like is it just plug and play or did you have to rewire the TB?
Old May 14, 2009 | 11:11 PM
iflyg5's Avatar
yes it works great from what jet told me is that it allows the computer to compensate for up to 45% more air flow then stock
awsome product for 136 bucks from were i work
Old May 14, 2009 | 11:50 PM
blackbolt89's Avatar
what are the documented gains on the jet maf alone.
Old May 15, 2009 | 10:53 AM
iflyg5's Avatar
^^^ i would say very minimal alone. But with an intake, manifold, tb prolly a couple hp
Old May 15, 2009 | 11:35 AM
1niceLS's Avatar
Yeah I own one as well I just thought it wouldn't be able to compensate for the TB the main reason for the tune to install the TB is because of the increased volume of air fudges the throttle position sensor but I guess since thats what the Jet MAF sensor does is recalibrates the ecu for increased air flow that it could work for installing the 2.4 TB.
On another note could you please tell me is the wiring the same for the 2.2 and 2.4 TB? I want to know if its just plug in and go or if you have to mess with the wiring for it.
Also one last thing if all this is true this would be a cheaper route then having to get trifecta tuned for your 2.2. No offense to anyone who has used trifecta or trifecta themselves Ive never heard anything bad about them and I m not trying to bash the company its just this way would be cheaper $136 compared to $250
Old May 15, 2009 | 11:48 AM
Chuck's Avatar
dude were do you work??.. I want one for 136 bucks
Old May 15, 2009 | 12:03 PM
1niceLS's Avatar
I went online and got one for roughly the same price go to autoanything.com
Old May 15, 2009 | 12:06 PM
IonNinja's Avatar
Wow $136 for an MAF sensor? Have a link to this?
Old May 15, 2009 | 12:11 PM
XgunsmokeX's Avatar
u need a stock MAF??
Old May 15, 2009 | 12:18 PM
IonNinja's Avatar
I was considering picking up a new maf and pigtail but not for $136 lol
Old May 15, 2009 | 12:20 PM
XgunsmokeX's Avatar
damn lol my dealer only wants 95 for a MAF lol
Old May 15, 2009 | 12:38 PM
he's talking about the JET MAF. not an oem one.
Old May 15, 2009 | 12:41 PM
XgunsmokeX's Avatar
yah well JET is not 136 lol
Old May 15, 2009 | 01:07 PM
Chuck's Avatar
Did you get Part Number: 69125
Old May 15, 2009 | 01:12 PM
hinow41's Avatar
Will these work on a 2.4 or are they just for the 2.2s upgrading to a 2.4 mani?
Old May 15, 2009 | 01:22 PM
Chuck's Avatar
^ x2
Old May 15, 2009 | 01:43 PM
xxxxsh4d0wxxxx's Avatar
Subscribed for sure!
Old May 15, 2009 | 01:54 PM
Maven's Avatar
Jet MAFs are really easy top find for like $175-180, $136 is probably shop cost or something.
Old May 15, 2009 | 01:59 PM
1niceLS's Avatar
I just tried looking up here www.auotanything.com that's where I purchased mine and it was for $134.95 and shipping was free. However, I just tried to find it through them and they don't sell it anymore
When I purchased mine they were available for both 2.2 and 2.4 but not for the 2.0. What it is is a reflashed stock unit used to recalibrate the ecu what people call a canned tune. All you do is use a phillips to take out your old MAF and put this new one in.
Old May 15, 2009 | 02:11 PM
Chuck's Avatar
Does it make the ECM think that incoming outside air is cooler that it actually is..
Old May 15, 2009 | 02:15 PM
1niceLS's Avatar
No at least not to my knowledge what it does is recalibrate the ecu to allow more air flow so it allows your intake system to draw more air
Old May 15, 2009 | 02:37 PM
hinow41's Avatar
So I would it "tunes" the computer to use more air?
Sorry for all the Dumb questions but I'm about to start doing work for more HP/T and this is my first time.
Old May 15, 2009 | 08:15 PM
iflyg5's Avatar
i work at bumper to bumper and i get all my parts at cost.. as for the maf for the 2.4L i have no idea
you know what i can't remember if the wiring was the same or not for the tb on the 2.4 vs 2.2 i have an 07 i thought it was a plug and play but i cant remember from my setup
pn is 69125 for 2.2 i dont know if its the same for the 2.4 i can check though
confirmed the 2.2l will work for the 2.4l
Old May 16, 2009 | 03:45 AM
Jn2's Avatar
Jn2
a trifecta tune will pwn the crap out of this POS jet maf...trifecta does a lot more than just tune for more air, they remove your PE delay, which is something that make 2.2's slower than they already are...u floor it, ur engine doesnt really do anything until ~5seconds after u go WOT, if you had a wideband u would see this, trifecta will remove PE dealy and do loads of other things, u think this MAF will compensate for more air??? load of horsecrap...
2.2's dont need anything to install a 2.4 manifold on their car, they just bolt it on and go, there is no need for this "jet maf" its just a waste of money, u want more power, get the car tuned
a MAF sensor will not recalibrate your ECM...its most likely lying ot yoru car about the air that is coming in, once again a MAF sensor will not calibrate ur ECM, u think it has the jet would charge so little for a tune??? no! once again that MAF sensor has no way of recalibrating ur ECM, no way in hell, it doesnt have the ability to travel up the MAF wires, make it to your ECM, and reprogram it with anything, its only lying to the ECM about the air its drawing in...
those maf wires do not have the power to reprogram anything!!! you really think that thru a 5 wires u can get to the ECM and change everything??? u really think that is possible??? u have a OBD2 port that has loads more wires, that leads to many other, that lead to the ECM, its has the power to get into the ECM and pull reading out and codes etc, your MAF wires do not
