jet module problems
Old Jun 10, 2008 | 06:52 PM
dem boyz's Avatar
Unhappy jet module problems
my stage 2 module is trying to engage my clutch and im wondering if anyone else is having this problem. do i need tuning or a tech 2 program to trouble shoot this problem. i installed it on a rental car and it worked but in my car no dice.
Old Jun 10, 2008 | 06:57 PM
halfj99's Avatar
um that makes no since how this piggy back type computer modification would in some way mess with a hydrolic clutch system
im trying to think of what electronic things would be on that system but i think its a very mechanical system
Old Jun 10, 2008 | 07:04 PM
dem boyz's Avatar
i know it is fine at first but after three stop and starts i take it out of gear and hold the clutch in it still jerks forward and stalls. but my cobalt came with an ss dash kit so would it be possible that i have miss matched parts?-from factory
Old Jun 11, 2008 | 10:25 PM
XM15's Avatar
How can the car jerk forward when the clutch is disengaged? Something is fishy.
Old Jun 11, 2008 | 10:29 PM
Delta2.2's Avatar
if ur a 5 speed manual................its not the module, its you
Old Jun 11, 2008 | 10:31 PM
yellowltcoupe22's Avatar
for one what the hell is an ss dash kit?? and two there is no way it can make somthin that is mechanical malfunction.. its impossible..
Old Jun 11, 2008 | 10:33 PM
XM15's Avatar
Maybe the trunk monkey has a friend in the engine bay...
Old Jun 11, 2008 | 10:35 PM
it must be the trans monkey...
Old Jun 11, 2008 | 10:59 PM
eazyasone23's Avatar
how does the module work for you when it is working? curious about this jet chip thingie.
Old Jun 12, 2008 | 10:59 AM
409Cobalt07's Avatar
this is what you get when you buy jet chips....
Old Jun 12, 2008 | 02:24 PM
dem boyz's Avatar
the chip works wicked when it is workin but im going to reinstall today after work to refreash my memory but it could also be somthing with the idle because it goes from 500rpm to almost zero then jumps up to2500 then wile comin down the car stalls.
my dash had the silver ss inserts in it when i bought it and w/out mods went like hell
Old Jun 12, 2008 | 09:55 PM
thats not an ss dash kit.. thats just an option that came on alot of the balts.. mine has it and its just an lt2. nothin special bout that.
Old Jun 12, 2008 | 10:41 PM
xxshadowxx's Avatar
your engine is dying or something. It is IMPOSSIBLE for you PCM/ECM to command your clutch to engage. Possible leaking slave cylinder?
Old Jun 12, 2008 | 10:59 PM
he even try'd to say it jerked forward after he pulled it outta gear.. thats what you call ****** impossible..
Old Jun 12, 2008 | 11:07 PM
xxshadowxx's Avatar
impossible for a PCM to do this... absolutely. If the PCM (or TCM) is commanding any type of gear engagement or changes then you are driving an automatic lol!
Old Jun 12, 2008 | 11:10 PM
joeworkstoohard's Avatar
that is a bad slave cylinder, most likely.
whats happeneing is, when the RPM goes up, it can't hold the spring in,a nd the clutch is engaging.
mine is also bad, and it rides fine under 3000 rpm, once it goes up, can't shift.
Old Jun 12, 2008 | 11:13 PM
xxshadowxx's Avatar
odd that RPM's affect you gear changes. With a leaky slave the only thing that shiould affect anything at all would be amount of time clutch pedal is held down. The slave fails due to fluid leaking/bleeding past a seal so the longer the pedal is held down, the more fluid is leaked. RPM's "should" not affect that really but i may be wrong >.<
man have ya'll not read what he said.. he said it jerked foward with the clutch engaged and out of gear.. how the **** can that be possible at all??? its not..
Old Jun 12, 2008 | 11:16 PM
well, you're right, i guess leaking isn't the right word.
long story short, it's a shitty aftermarket cylinder that came with my clutch kit. it's the only part that wasn't replaced after it started acting up.
xxshadowxx's Avatar
OHHHH lol i didnt get at what you were saying. Totally skipped past that whole "out of gear" thing. Aside from poor cable adjustment (possible shifter replacement?) that is impossible good catch man
Old Jun 12, 2008 | 11:18 PM
that's a good point, or perhaps something is damaged in the shift assembly on the trans.
Old Jun 12, 2008 | 11:20 PM
xxshadowxx's Avatar
Yah. Only way you canbe sure of anything is to remove so called "Jet chip" and see if problem persists. If you remove part and the symptom is gone its pretty safe to say this chip is garbage
Old Jun 13, 2008 | 03:46 PM
dem boyz's Avatar
my engine is fine , my dash had a ss badge on it and the chip is working better gm mechanic says i need to do somemore tuning because my computer has a funny glitch and it has to be programmed out because he says its trying to think like an automatic. if this does nothing its going back to jet.
Old Jun 13, 2008 | 05:40 PM
XM15's Avatar
How can your car think its an auto? Its still impossible for it to engage your clutch.
Old Jun 13, 2008 | 05:42 PM
an0malous's Avatar
sounds like clutch is toast to me
if you go back to stock tuning does it do it?
