JET Stage 2 Module
Old Jul 21, 2008 | 11:20 PM
08slatecobalt's Avatar
JET Stage 2 Module
For those of you that saw it in the classified section, I purchased the JET Stage 2 Performance Module for my 08 2.2. Put it in, and my car feels a lot better than it did. It pulls hard in any gear and pulls right up from 60 in 5th gear. Definitely a good purchase.
Old Jul 21, 2008 | 11:31 PM
Red07SSNA's Avatar
Glad to hear it's working for you....keep everyone up-to-date on its' reliability too.
Old Jul 22, 2008 | 06:37 AM
Whitty's Avatar
thats amazing! i considered buying that module but considering all the contraversy and the fact he was a new member and all i didnt. glad to hear it works perfectly. is there someway you can take it on a dyno and prove what kinda of numbers it gives as this is something i am going to be very interested in down the road? Also what mods are you running performance wise your sig doesn't list any.
Old Jul 22, 2008 | 07:36 AM
Unfortunately the guy that I would have taken it to for the dyno had a fire in his shop a couple weeks ago, so I cant get that for you guys. As far as performance stuff, this is the only mod I have done to the car.
Old Jul 22, 2008 | 08:14 AM
08ls-coupe's Avatar
the jet stage 2 chip is designed for a car modded with high flow exhaust and cooler thermostat, also a more breathable intake, once you get those your car should really wake up
Old Jul 22, 2008 | 08:25 AM
Chuck's Avatar
I contacted Jet myself to get some info in the Module...On the stage 1 chip they claim that there is a 12WHP and 14ft LB of torque. for the 2.4 ectoecs. thats pretty good numbers... Keep us posted on how the stage 2 is working out for ya..
Old Jul 22, 2008 | 10:14 AM
CPerez1217's Avatar
I Have it on a 08 2.2 l 2 lt I have the gm intake and gm exhaust with the RK ram air hood and it flies. The car runs strong no weezing like it does without it and i am very happy with the power it will chirp and wheel hop second to giv eyou an idea of the tourque increase that never happend without it even with the other mods.
Old Jul 22, 2008 | 11:39 AM
Whitty's Avatar
really i have been able to do that from day 1 on my 2.2 oh well. actually if i am really giving it i can get 3rd to chirp sometimes. not that, that is the best as far as getting good 1/4 times but oh well :P lol
edit:
also what is the 180 thermostat do ? Thanks always wondered this
Old Jul 22, 2008 | 12:21 PM
Red07SSNA's Avatar
edit:
The comment about the 180 thermostat on the Jet Chipwebsite is a generic statement for all cars. The Cobalt is equiped with a 180 thermostat. Most cars come with a 192 degree thermostat so a 180 ts would make those engines run cooler by 12 degrees.
Old Jul 22, 2008 | 12:45 PM
Whitty's Avatar
right on! thanks for the info
Old Jul 22, 2008 | 07:20 PM
YSUsteven's Avatar
I want to see dyno results before I consider it.
Old Jul 22, 2008 | 07:44 PM
scotch89's Avatar
ya i have a k&n typoon intake, 2.4l intake many, 2.5 magnflow exsaughst, and on the way that chip should be here its just a waiting game so when i get it ill for sure post i just cant wait from all these good respones ive heard on these chips!!!!
Old Jul 22, 2008 | 07:57 PM
FASTL61's Avatar
when i test drove my car i hit second and spun the **** out of the tires(plural)i t started goin into the other lane,even when i was tryin to correct it (since there is little steering when your spinning tire)
Old Jul 23, 2008 | 08:07 AM
Whitty's Avatar
for those with the module on the 08 can you take a pic installed ? how hard was it to access the computer, sorry i haven't started digging in my engine bay yet on this car :P
Old Jul 23, 2008 | 10:18 AM
CPerez1217's Avatar
will take a pic and post for you ina few mins.
Old Jul 23, 2008 | 10:28 AM
Whitty's Avatar
thanks alot!
Old Jul 23, 2008 | 10:57 AM
CPerez1217's Avatar
jet chip location
Old Jul 23, 2008 | 11:27 AM
Whitty's Avatar
right on, that doesnt look hard to install at all... is that an 08 thats pictured ?
Old Jul 23, 2008 | 11:30 AM
CPerez1217's Avatar
yes its an 08 2.2l 2lt I took it so you can see it relative to the rest of the engine bay its just under the cover on the right handside when looking at it. easy to install as well
Old Jul 23, 2008 | 11:33 AM
PSPCobalt's Avatar
Does It Work For The 06 Because I Dont Have That Box Where The Chip Is Located
Old Jul 23, 2008 | 11:47 AM
OrngBalt's Avatar
no, they are working on it.
search for my thread on jet chip doesnt fit 2.2
Old Jul 23, 2008 | 12:29 PM
Whitty's Avatar
right on thanks a lot CPerez1217 beautiful car btw!
Old Jul 23, 2008 | 01:26 PM
PSPCobalt's Avatar
Thanks Man This Is Pretty Cool since i just found out i couldnt put headers cause i have the sai might as well put the chip instead
Question.What Happens If U have The SAI And U Install Headers Will It lose Power
Old Jul 23, 2008 | 01:35 PM
Whitty's Avatar
it'll probably flip out on you big time! SAI means that fresh air is added to the exhaust as of now there are no aftermarket headers that are SAI compatible. i wouldn't even consider that if i was u for the time being. if in fact you do want a header you are going to need something other than a jet chip. there are tuning options available with trifecta that can do an SAI delete maybe you should look into something like that ?
Old Jul 23, 2008 | 02:08 PM
CPerez1217's Avatar
Thanks Whitty. I dod the RK body kit on it and i have borbet wheelsyou can check it out in the gallery.
