Just Trifecta Tuned my Cobalt?
Just did the trifecta tune now I have a P0171 code system to lean. I havnt been able to dat log yet. BNR says it can be a wait cause trifecta is out till the 18th. I can def feel a difference. Exept at idle is rough. And ofcoarse I have the P0171. Is this something that will be fixed through data logging?
When I first got my injen intake SRI I got a lean code. Maybe its the injen? Someone told me to check for air leak then. I tightened everything down which the bolts seemed loose and the went away never came back. I will take advise, tuning back to stock right now
So I put my car back to stock. My option for secondary injection isn't there? And it still idling rough after putting stock tune? Gonna try to program it to stock again
Starting to think this tune is awaste. Now I'm told if I go back to stock and have the same issues its not from the tune. I had the damn car 4 years and now all of a sudden its not the tune. Lol
I was wondering cause I wanted to turn off rear cat code when I go catless. But anyways I just got a smoke test done injector 4 was leaking smoke. I'm thinking maybe it could be the problem?
Yes a bad seal it sounds like. Sucks that this happened right now. I hope the code goes away after I get it fixd. Should I get new injectors or just use the old ones?
Luckly the guy did the smoke test for free. Crossing my finger on the seals. Went home after smoke test my friend sprayed the injectors and the same one that leaked sucked it right in and started acting wierd
Well this is weird. Took injen filter off no code so far. I hant been driving with filter off sitting in garage. Code been usually showing soon as I start the car. Maybe injen intake
