Just Trifecta Tuned my Cobalt?
Old 12-12-2013, 10:37 PM
raymoore1982's Avatar
Just did the trifecta tune now I have a P0171 code system to lean. I havnt been able to dat log yet. BNR says it can be a wait cause trifecta is out till the 18th. I can def feel a difference. Exept at idle is rough. And ofcoarse I have the P0171. Is this something that will be fixed through data logging?
Old 12-12-2013, 10:40 PM
Is this a base file? i.e. is this the first time youve been retuned?
Old 12-12-2013, 10:53 PM
Got Brakes?
Sox-Fan's Avatar
Make sure you don't have an air leak somewhere. If I remember right that's bank 1 lean, which is usually an air leak between MAF and throttle body. Before the throttle body for sure.
Old 12-12-2013, 10:59 PM
I checked for possible leaks. This is the first time I flashed the car that the only thing I did was flash the first tune file they sent me
Old 12-12-2013, 11:02 PM
blueLNFftw's Avatar
Log it for a bit and then just flash it back to stock if you are worried. Send them the log and see what they say.
Old 12-12-2013, 11:05 PM
You cant expect a base file tune to be perfect. About your code, i would listen to soxfan.
I think bnr is flashing it for him so he might not be able to
Last edited by Slowbalt2000; 12-12-2013 at 11:05 PM. Reason: Automerged Doublepost
So the stock flash is what origanally came on my car? I don't want to run lean for a week. Think I should flash it back to stock for now?
Old 12-12-2013, 11:07 PM
Would be a good idea.
Old 12-12-2013, 11:10 PM
When I first got my injen intake SRI I got a lean code. Maybe its the injen? Someone told me to check for air leak then. I tightened everything down which the bolts seemed loose and the went away never came back. I will take advise, tuning back to stock right now
Old 12-13-2013, 12:33 AM
So I put my car back to stock. My option for secondary injection isn't there? And it still idling rough after putting stock tune? Gonna try to program it to stock again
Old 12-13-2013, 06:50 AM
blueLNFftw's Avatar
What car do you have?
What option?
Old 12-13-2013, 12:40 PM
My car is a 2.2 cobalt. What do you mean by options?
Old 12-13-2013, 01:31 PM
Got Brakes?
Sox-Fan's Avatar
p0171 on trifecta. idling rough on stock.
hmm.
Old 12-13-2013, 02:01 PM
Starting to think this tune is awaste. Now I'm told if I go back to stock and have the same issues its not from the tune. I had the damn car 4 years and now all of a sudden its not the tune. Lol
Old 12-13-2013, 03:49 PM
How can I manage to get to this check box screen? Name:  2013-12-12181804-1.jpg
Old 12-13-2013, 04:57 PM
blueLNFftw's Avatar
Do not shut the code off
Old 12-13-2013, 05:57 PM
I was wondering cause I wanted to turn off rear cat code when I go catless. But anyways I just got a smoke test done injector 4 was leaking smoke. I'm thinking maybe it could be the problem?
Old 12-13-2013, 06:05 PM
Probably lol. Bad injector seal?
Old 12-13-2013, 06:11 PM
Yes a bad seal it sounds like. Sucks that this happened right now. I hope the code goes away after I get it fixd. Should I get new injectors or just use the old ones?
Old 12-13-2013, 07:32 PM
NWAE Cobalt's Avatar
old ones are probly fine. Start with the cheapest option..IE new O rings and try again, if still lean/ smoke then replace injector.
Old 12-13-2013, 07:38 PM
Luckly the guy did the smoke test for free. Crossing my finger on the seals. Went home after smoke test my friend sprayed the injectors and the same one that leaked sucked it right in and started acting wierd
Old 12-13-2013, 07:43 PM
Wonder why? Lol what did he spray it with
Old 12-13-2013, 07:55 PM
Some carb spray. Only happen in injector #4. My guess is after the tune when I went out smashin on the balt a seal came loose, possible?
Old 12-14-2013, 09:23 PM
Well this is weird. Took injen filter off no code so far. I hant been driving with filter off sitting in garage. Code been usually showing soon as I start the car. Maybe injen intake
Old 12-14-2013, 09:33 PM
Finding oil in intake tube. Sensors probly all oiled
Quick Reply: Just Trifecta Tuned my Cobalt?
