L61 S/C questions
Old 10-24-2011, 06:24 PM
Under Pressure's Avatar
L61 S/C questions
I am In the process of aquiring parts to S/C my Ion. So far I have all major components but some of the smaller parts are harder,and expensive to come by. So I thought I read somewhere(there are so many build pages) you dont need the LSJ tensioner you can put a pulley near where the allenhead plug is on the block/head area. Am I right? cant remember where I saw it and have read thru alot of build articles and almost all list lsj tensioners. Any help on that would be appreciated.
Also my ride is an 05 Ion and what I am reading Trifecta is my only tune option. Is there anyone else that does the L61? Thanks for any help.
Old 10-24-2011, 06:31 PM
1LowLS's Avatar
Never heard of running said pulley instead of the LSJ tensioner setup.And Trifecta is your only option unless you run a stand alone unit.
Old 10-24-2011, 08:12 PM
IonNinja's Avatar
Doesn't ZZP use some alternate belt setup in their kit?
Old 10-24-2011, 08:13 PM
1LowLS's Avatar
Never seen it.
Old 10-25-2011, 02:27 AM
IonNinja's Avatar
yeah looks like they do
Cobalt & Ion ---> ZZ Performance
might want to check w/ ZZP and see if its something they can give you more info on. most people just swap the LSJ stuff over though
Old 10-25-2011, 08:29 AM
06_cobalt's Avatar
ZZP uses a 5 rib pulley for the 2.2 and a custom modular pulley system so you don't have to swap everything over from a LSJ.
Old 10-25-2011, 09:11 AM
thanks for the input. I think that zzp setup is what I have seen before.
DarrenGC
12-24-2021 01:55 PM
brandon04
10-21-2015 07:04 AM
ThoR294
10-04-2015 08:44 PM
Extremespeed
09-29-2015 04:34 AM
09-26-2015 06:44 PM
Quick Reply: L61 S/C questions
