Ls4 tb?
Whats the hahn intake made for? The LSJ TB or the L61? If it was made for the LSJ TB then get the adapter plate from RAW or who ever sells it now. The L61 or LSJ TB should be sufficient enough.
ok i think the intake manifold is matched with the L61.
do you happen to know the exact size of the LSJ tb or the 2.4? Ive heard 68 to 70mm
the reason for the LS4 is because i will be in the area of 600hp
im going stand alone engine management (Fast XFI) and im just gathering parts the real work is being done by 2 different places. Jotech Motorsports and Marty Ladwig Racing/GM racing.
but you do have a good point on the honda running them it slipped my mind. most of the honda guys i know all have 75mm tb from skunk2
well i know that the 07 2.2's placed a crank sensor on the crank so that should be taken care of. im just having that one taken off and placed on my eagle crank. as far as the trigger wheel i spoke to FAST already and they said that they have one for my application
hey ion what made u go with the comp blower cams? i was look at some comp cams today and im not sure which ones to go with..are these cams specific to motors with a blower? the 2.0 ecotec and how much did they run u.. the kit i was lookin at was like $459
yup that sounds good man. what do u run in the 1/4?
the tranny issue im thinking of cryo treating it and using a stage 4 or 5 custom exedy clutch and the light exedy flywheel
o and dss axles. i just dont know what stage to get at the moment. the 2 or the 3
Last edited by 06cobaltindallas; Aug 6, 2009 at 10:56 PM. Reason: Automerged Doublepost
