LSJ Downpipe Installed on 2.2
Old Mar 24, 2009 | 06:53 PM
OBZ's Avatar
OBZ
Well I just got done installing my new LSJ DP on my 2.2. Currently I have the racing solution shorty 4-1 header and a Corsa sport cat-back. The LSJ DP was a really good way to finish off the exhaust! I felt a difference as soon as I pulled out of my driveway. And the car really pulls quite a bit harder from 5000-6500 RPM.
Check out the difference..
This is a very cheep solution for any 2.2/2.4 owner that needs a downpipe.
Keep in mind that this is only a direct bolt on for G5/Cobalts with MANUAL transmissions. the motor sits a bit different with the automatic transmission.
Old Mar 24, 2009 | 07:09 PM
Gestapo007's Avatar
^wow very nice. didnt think the 2.2 DP was that crappy lol
Old Mar 24, 2009 | 07:11 PM
DJVC's Avatar
I got my LSJ DP from another member for $50. and i have an auto too and it makes the dp sit a slight bit lower and my dp will scrape on big speed bumps. But every worth getting tho.
Old Mar 24, 2009 | 07:28 PM
Jn2's Avatar
Jn2
i just put one on my car for my sc build hahaha, had to keep costs down
Old Mar 24, 2009 | 07:31 PM
OBZ's Avatar
OBZ
Yep its just a tiny little thing (thats what she said anyways.. )
So did it directly bolt up? I heard its about 2-3 inches too short for the auto's
Old Mar 24, 2009 | 07:45 PM
BLKLS's Avatar
yeah, i thought it made a good bit of differince, def. worth the 50 bucks
05LSCobalt's Avatar
exactly what i got and yeah i was ashamed at the size of the stock 2.2 DP. looks like a damn pea shooter. haha. looks good man.
Old Mar 24, 2009 | 08:15 PM
OBZ's Avatar
OBZ
Yeah for sure! I got mine for 60 shipped from littlegoose. (good seller BTW)
No doubt! I didn't think it was that small until i held it up to the LSJ DP lol
Old Mar 24, 2009 | 08:29 PM
05LSCobalt's Avatar
so you got a full exhaust obz? header, lsj dp, and a catback? how much diff did you notice with the full system?
Old Mar 24, 2009 | 08:48 PM
OBZ's Avatar
OBZ
Yep I have the racing solution 4-1 shorty header for the 2.2 - LSJ DP - Corsa sport cat-back.
I have noticed a big improvement from stock! the biggest jump was from the header! Its amazing what it did for my top end..
Old Mar 24, 2009 | 09:25 PM
Gestapo007's Avatar
u got an exhaust clip?
Old Mar 24, 2009 | 09:55 PM
OBZ's Avatar
OBZ
I'll get one. All I have is a shitty camera though. So it won't be the greatest quality. and I'm sure it won't so it any justice.. but it sounds mean!
Old Mar 24, 2009 | 09:59 PM
05LSCobalt's Avatar
sounds like next pay check im getting the header. and then the mandrel bent magnaflow catback.
Old Mar 24, 2009 | 10:04 PM
BLKLS's Avatar
i did header, then dp then exhaust, i think the best gain was from the dp. the header made a good differance, but i think the dp made the biggest gain. hohonestly the cat back just made it louder, i really didn't notice much of a gain, then againe i swapped cat backs in the middle of a 2 week rain period so it ook awhile before i could beat on it after so i don.t have a sameday comperison.
Old Mar 24, 2009 | 10:41 PM
OBZ's Avatar
OBZ
Well my ecu is still learning the new flow so I'm sure it will get a little better. Once I get the 2.4 intake manifold I'll get a tune. Then I should see a good gain!
Old Mar 25, 2009 | 11:20 AM
007CobaltLS's Avatar
You're the only person I've heard mention the issue with the auto and LSJ DP...if there's any truth to it not fitting, then I'll have to look into the ZZP mid lenght setup again, but can anyone else say for sure that it will fit with an auto?
I would assume so, but please tell me it will.
I don't want the Cobalt to wind like my old Saturn SC1 where they made a CAI, but the catch was it only worked with manual trans, auto were stuck with SRI unless they custom made one because of the tranny filter.
Old Mar 25, 2009 | 11:30 AM
originaladrian's Avatar
i need to get a resonator welded in before i put thatDP back on my car. sooooo loud....
Old Mar 25, 2009 | 12:05 PM
Blue_Balt's Avatar
That 2.2 DP is much more restrictive than I thought!
The LSJ DP is definitely on my to do list.
Old Mar 25, 2009 | 12:37 PM
tonio5555's Avatar
The LSJ DP bolted right on to my auto 2.2, no issues.
Old Mar 25, 2009 | 12:49 PM
ebristol's Avatar
Here is another unfair comparison.
Stock 2.2 dp VS ZZP 3" cat'd dp with 2.5" flange.
Old Mar 25, 2009 | 12:50 PM
Red07SSNA's Avatar
No issues at all? I have found on both 2.4s and 2.2s with autos the LSJ didn't just bolt in...what cat-back do you have?
the LSJDP is shorter and the cat sits on the sway bar without some adjustments.
Can you post some pics of your install?
Check out my thread, and I have run into this on an another 2.2 auto equipped LS:
https://www.cobaltss.net/forums/show...&highlight=LSJ
Old Mar 25, 2009 | 12:55 PM
baggelis's Avatar
i thought that the lsj dp doesnt bolt up to the autos
i thought its too short cause the engine sits further up front to the autos
Old Mar 25, 2009 | 01:31 PM
tonio5555's Avatar
I have a 2006 2.2 auto (with SAI). I had the LSJ cat back then I installed the LSJ DP over a year ago. On my car the LSJ DP is a tight fit but its in there without any rubbing. I will soon (within the next few weeks) be installing an LSJ exhaust manifold. When I get under there to do the manifold I'll definetly get some pics for you.
Old Mar 25, 2009 | 08:26 PM
thisperishedmin's Avatar
funny how much of a difference .25" makes haha.
Old Mar 25, 2009 | 10:57 PM
baggelis's Avatar
so the lsj dp does bolt up to an auto 2.2?
