LSJ Injector Wiring for Supercharger Build
So the stock wiring harness for our injectors are 8 pin. I bought 60's with a ZZP harness for the LSJ that is 5 pin. Does anyone know what I would need to cut and splice to make the harness I have work with out stock wiring harness? I need help ASAP please.
the lsj harness wont connect to the ls harness, i believe that the lsj harness is also missing the map harness.. you should just buy a l61 harness from ebay and hack it up so you can keep the harness you have now for stock injectors just incase you need to go back to stock.
I cant cut the injector plugs off my old and new harnesses and swap them around? That seems like the easiest way to do it.
If I have to go back to stock, I'll just buy a new harness along with all the other parts that I would need.
