lsj/lnf internals
Old Apr 2, 2014 | 08:33 AM
flaminace's Avatar
lsj/lnf internals
has anyone ever put the lsj or lnf pistons and rods in the 2.2? i know it would destroke it, but wouldnt that lead to safe higher revs? also, stock upgrade is less expensive than aftermarket. i plan on doing a mild turbo build on my 2.2 (because it has almost 120k miles on it) and im on a very strict budget. but basically, i could get around 350 whp with the factory internals setup, right?
Old Apr 2, 2014 | 09:20 AM
05g5's Avatar
https://www.cobaltss.net/forums/2-2l...ability-58013/
lnf internals, no. Atleast not the pistons. DI engine.....
Old Apr 2, 2014 | 09:24 AM
umrdyldo's Avatar
The stock bottom end is good for 250HP i believe.
So you will need upgraded rods and pistons at a minimum. No the LNF parts won't work.
Old Apr 2, 2014 | 09:46 AM
flaminace's Avatar
05g5, saw that thread.
The L61 is rated for 250hp I believe. Unless the lsj is the same. I'd think the lsj could take more having thicker rods and taller pistons. Am I wrong?
Old Apr 2, 2014 | 10:17 AM
05g5's Avatar
the lsj is boosted + forged internals. it will handle more.
any parts YOU are looking are gunna need to come off a LSJ
Old Apr 2, 2014 | 10:19 AM
BlackielawlessSS's Avatar
Like everyone else said, use LSJ internals. If you are on facebook the cobalt ss gang someone has the pistons and rods forsale.
Old Apr 2, 2014 | 10:58 AM
flaminace's Avatar
I sent a request to join the group. Lsj rods and pistons are capable of 450ish hp, right?
Old Apr 2, 2014 | 11:06 AM
Technically the lnf stuff fits too, and the DI pistons dont affect much for non DI. Somebody even ran flat top pistons for a DI build and they said nothing really changed.
Zzp sells brand new ldk pistons/rods/rings for 250$. Go for those.
Old Apr 2, 2014 | 11:08 AM
flaminace's Avatar
That sounds tempting, but I'm going for price efficient and around 350whp, call said and done. So if there's not much of a difference in price, I'll go with ldk stuff to be safe.
Old Apr 2, 2014 | 11:25 AM
umrdyldo's Avatar
LDK is direct injection I believe. Pistons won't work. They are dished for DI
Old Apr 2, 2014 | 11:40 AM
flaminace's Avatar
Wouldn't dished in a non di car just lower the compression?
Old Apr 2, 2014 | 11:43 AM
Pitbull2o08's Avatar
This was just addressed above. DI pistons won't change the CR much on an nonDI set up.
Old Apr 2, 2014 | 11:45 AM
umrdyldo's Avatar
I believe the reason the DI piston are dished the way they are is for proper burn of fuel from the direct injection finer mist. .
I may be wrong. I'm not sure anyone has tried those pistons on an LSJ or 2.2 car.
flaminace's Avatar
So what the hell is the difference? Lmao
I mean, if it's the burn, I'll have 60lb injectors. Not sure if that'll be ok or not, but yea. Lol.
Old Apr 2, 2014 | 12:05 PM
flaminace's Avatar
So, on the zzp website, it says the take out lnf/ldk pistons and rods will work in an lsj. Therefore, they should also work in the 2.2 engine. Correct?
Old Apr 2, 2014 | 12:18 PM
yes... this is what i said lol
Old Apr 2, 2014 | 12:24 PM
What about the LE5?
le5 has a different bore and a different length rod.
Old Apr 2, 2014 | 12:50 PM
So no, then. Lol
What alternative upgrades do you recommend? 06 LE5 rods, forged pistons?
Old Apr 2, 2014 | 02:29 PM
flaminace's Avatar
Lol. Sorry man. I'm running off 3 hours of sleep, and I'm sick. My head is not all there at the moment. Since zzp is out of stock on the ldk rods and pistons, I think I'll get some stock lsj's I found on eBay for $180. Waiting for the turbo kit is going to be the hardest part. =\
Old Apr 2, 2014 | 03:30 PM
mrbelvedere's Avatar
the lsj stock bottom end has handled 500hp
by changing the rod length you do not destroke an engine
the lsj rods are not a true forged rod they are cast then hit with a rod press a few times then the cap broken off
lsj rod is a lot shorter then the 2.2 so if you used a lsj rod and piston you will lower the compression roughly half a point or a little more a few people have done the lsj rod piston combo swap into a 2.2 years ago
Old Apr 2, 2014 | 04:16 PM
sandman's Avatar
What turbo kit did you get?
Old Apr 2, 2014 | 04:22 PM
flaminace's Avatar
Haven't gotten it yet, but I'm getting the zzp bolt on for the 2.2 with the stage 3 options.
And mr.belvedere, thank you.
Old Apr 4, 2014 | 06:05 AM
flaminace's Avatar
You wouldn't happen to have a link to that, would you? I can't find anything on it.
Old Apr 8, 2014 | 06:38 PM
Quad-coupe07's Avatar
Do u need to use a lsj crank to for the swap?
