MSD Ignition
Old Dec 22, 2007 | 01:57 PM
Ec0t3cHp0w3r's Avatar
MSD Ignition
i am thinkin ab gettin msd ignition soon... and idk wat 2 get!!! there is a DIS(distributorless ignition system) one 4 ab $500, and one thats called MSD Ecotec Ignition Sync Distributor 4 $290 at turbotechracing.com which replaces the power steering pump... idk wat 2 get!!! i think with the sync dis. it calls 4 aftermarket injectors, but does the DIS call 4 them 2???? help please! thanx
Old Dec 22, 2007 | 01:59 PM
redlineblueline's Avatar
hold on and let me find the link to what you need
this one here
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/msd-ignition-now-possible-ecotecs-coil-plug-56341/
Last edited by redlineblueline; Dec 22, 2007 at 01:59 PM. Reason: Automerged Doublepost
Old Dec 22, 2007 | 02:17 PM
hmm thanx.. but they r basically just talkin ab wiring up the coils.. hmm i am wanting 2 know which one is better 2 get... or if there is a better one...
Old Dec 25, 2007 | 12:05 AM
Novajoe's Avatar
which one do you want? You have a DIS now stock. The MSD replaces that system and you can tune it.
The sync system replaces your stock DIS system with a distributor system. I'd say stick with the DIS unless you plan on wiring up a megasquirt or something.
Then again I would do some reading on both and how they work and how to tune them before you do anything.
Old Dec 25, 2007 | 11:47 AM
yea, thats wat i am tryin 2 figure out.. which one would b easier 2 tune and which one would b the best... idk
Old Dec 25, 2007 | 07:59 PM
Novajoe's Avatar
it's about the same to tune either way. The only difference is the distributor system actually uses contact points to distribute spark whereas the DIS uses an ignition module. In our case our stock ignition module is pretty much just a "dummy" and the actual ignition patterns are saved in the pcm.
Think of a distributor system as OBDI and DIS as OBDII.
Unless you're planning on going with a full standalone ecm(like megasquirt) that requires you to change your ignition there's really no point in making the swap though. The MSD systems won't perform any better than your stock ign system. Certain packages will allow you to advance or retard timing or set a stage rev limiter, but there are plenty of easier methods of doing this without changing out your entire ignition system.
If you really feel you need to do this then go with the DIS system. It would be a ton of work and fabrication to run a distributor on our engines.
Old Dec 26, 2007 | 11:06 AM
thats all i needed 2 hear man thanx alot!!
ricklovin93
Aug 27, 2016 06:35 PM
Shanman
ZZ Performance
43
Aug 26, 2016 08:43 PM
satisfied
Oct 19, 2015 12:35 AM
Cptnslo
Sep 24, 2015 09:32 AM
Wind
Sep 11, 2015 06:57 PM
