muffler size
just need to to know the size????
just get one with a 2.25" inlet that way when you replace the rest of the exhaust you don't need to get another muffler. besides, an exhaust shop will put whatever extension you need to fit it to your stock exhaust
i sont know if you could say one way or the other. the stock muffler is a weird ass box shape kinda, so it would be hard to say i do know it is not a strait flow through... i want to say it flows in the right side and out through the left if your standing at the back looking at the car.
I've heard that the the exhaust tapers from 2.5" to 2.25" somewhere just before the muffler.
So I'd take 5 minutes to get under your car and measure everything. Then look at your books to pick out a muffler with 2.5" in and out. Go to muffler shop and have them cut out 2.25" section, make whatever pipe you need and install your muffler.
That depends. If the stock system has the same pipe size as a catback you can get roughly the same power increase by just replacing the muffler with a freeflow.
If the muffler is the most restrictive part of the exhaust then you can get more performance by using a less restrictive muffler. But if the cat is where the restriction is, the muffler won't do much more than change the sound.
Last edited by DrPuttsSS/SC; Aug 15, 2007 at 10:25 PM. Reason: Automerged Doublepost
