My car is acting crazy! Please help!!
Old Jan 21, 2011 | 06:52 PM
NORTH TEXAS TBSS's Avatar
Ok so the car wouldn't start this morning (I think the 15* weather last night drained it) so I get my friend to jump it off. Got it running and went to drive and the TC, ABS, check engine and check power steering lights came on And the speedometer will not work. When driving at like 20mph it's a 3500-4000 rpm! I thought ok maybe the battery is bad or somethin so I put a brand new battery in it and it's still doing the same thing. The check engine code is U0101... I'm scared to drive the car cause i I don't want the motor to blow up and I have no other transportation right now. Anyone know what's goin on?? Thanks in advance for any help
-Nathan
Old Jan 21, 2011 | 07:14 PM
BlackLsCoupe's Avatar
posting this twice wont get you help faster. im of no help on this im stumped. is it still under warrenty? first thing id suggest is takeing it to a dealer, most likely cause is something electrical is going bad
Old Jan 21, 2011 | 07:34 PM
Ya I noticed I put it in the wrong section so I put it in the other too.. Ya it's still under warranty but I don't wanna pay the copay or deductible if it's something simple that i can fix that's why I asked you guys first..
Old Jan 21, 2011 | 07:42 PM
if its under the factory warrenty you wont pay anything. if you have the extened yea you do but its worth it, thing like this could be a easy fix or end up being a total loss of a car
Old Jan 21, 2011 | 07:57 PM
kxrida2000's Avatar
according to the code its something to do with ur tcm..cant help much besides that
Old Jan 21, 2011 | 08:29 PM
RecklessL61's Avatar
your promblem is you alternator, its not providing enough power to those systems so they are shutting, i had the same problem with my altornator on my 07 cobalt
Old Jan 21, 2011 | 08:30 PM
Magz_rule's Avatar
x2 on the alt
Old Feb 15, 2011 | 10:00 AM
ShadowStal3er's Avatar
either that... or when your friend jumped you he wrecked your computers... they may not go immediately, but if jumped wrong... your toast...
Old Feb 16, 2011 | 06:59 PM
Mike85220's Avatar
Yeah, a lot of people still think they can jump modern cars like their old carbuerated ones.
It needs the ground to be on the frame and not on the battery.
Correct me guys if I am wrong.
I was told if you don't ground it somewhere on the motor or frame it has a chance that it will fry the computer.
Old Feb 16, 2011 | 08:11 PM
HyperMuffin's Avatar
Doesn't matter if its on the frame or the terminal. I jump cars all the time in my school auto shop and hook both cables to both terminals of the battery and never had a problem.
Old Feb 16, 2011 | 08:13 PM
chris88z24's Avatar
There's a spot on the strut bolt for the jumper ground. If you don't hook it there then you're a dope.
Old Feb 16, 2011 | 08:16 PM
Well its easy to jump the cobalt. Hugh terminal by the fuse box for (+) and just clamp the negative on the body or some unpainted surface.
Old Feb 16, 2011 | 08:34 PM
jonxxxedge1's Avatar
the point of not having the ground on the battery is because it can spark. and the battery puts off a gas that is flammable
Old Feb 17, 2011 | 02:34 AM
zerosk8ter83's Avatar
I got lsj alt for sale lol just throwing this out there
Old Feb 17, 2011 | 10:59 PM
Mike85220's Avatar
Then what is the correct way to jump a car that has a computer?
I might be wrong, but I detect that my statement about using the frame for the negative is not being believed.
Old Feb 17, 2011 | 11:46 PM
Just like any other car, there are fuses to prevent anything from getting "fried". Your computer "relearns" within the first few mins (hence why when you add an intake you should disconnect your battery)
His car isnt messed up from getting jumped, there is another problem, dead battery, dead alternator or something else, best bet it to take to to someone who knows what they're doing, stop being a cheap ass and take it somewhere /end rant
Old Feb 21, 2011 | 10:54 PM
Phil424's Avatar
This happens alot whenever the alternator goes bad. The alt is suppose to send AC current but because its going bad it sends DC current which messes with the systems. Also a lack of power to the systems also cause this.
Old Feb 24, 2011 | 06:41 PM
cobraceralt's Avatar
when i do need a jump i always hook up both cables to the battery and i dont have that issue. grabted its an LS so idk what diff it would make
The Rookie24
Jan 20, 2016 05:14 PM
footballplaya3k
Wheels and Tires
Oct 8, 2015 05:24 PM
vjoel2011
Oct 2, 2015 12:11 PM
no_ss
Sep 18, 2015 11:03 AM
ROADKONE
Sep 9, 2015 02:32 PM
