Na STG 2 Comp cams installed Instead of turbo grind
Old Jul 17, 2015 | 02:38 AM
M62's Avatar
M62
Well When I had a machine shop put together my head and port it they put cams that are for NA..
Or as It seems AM I wrong?
INT CAM: Lift .440
Cam Lobe Lift .260
Valve Lift 258
Valve timing @ 0.050 41 bbd 3- ATD
Duration @ .050: 216
Exh Cam Lift .436
Cam lobe lift .258
Valve lift 262
Valve timing @ 0.050 2- btd 38 ATD
Duration @ .050: 218
Does anyone know best specs for big turbo 2.2l? Or have a Recommendation for an Aggressive Turbo Grinds I have an EFR 8374, Head is 94lb springs +1mm Valves And Im thinking these are hindering me rather than helping me. No Dyno to confirm anything yet Obvs
Old Jul 17, 2015 | 02:48 AM
If you got adjustable gears you could probably make them work okay
Old Jul 17, 2015 | 10:39 PM
Jesse's Avatar
Those sound like the stage 2 supercharged cams that I have. Still way better than stock 2.2 cams
Solaris99
28
Mar 15, 2017 01:22 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
