new custom turbo kit
Old Aug 10, 2011 | 02:03 PM
killswitch1209's Avatar
[IMG][/IMG]
Old Aug 10, 2011 | 02:16 PM
MastaShaKe_88's Avatar
fix yer picturessss
Old Aug 10, 2011 | 07:53 PM
PsychoCam's Avatar
if ur maf sensor is on the intake pipe you are going to have to recirculate the bov back into the intake. you will run into a lot of idle problems and car running too rich if u leave it like that.
best bet is to reroute the maf after the bov and b4 the throttle body.
looks good still needs some touch ups tho and the kit will look good
specs on turbo? manifold? etc
Old Aug 11, 2011 | 12:00 AM
i herd the stock maf sensor will not see boost how will it not work why does it have to be before the throttle body? its a log style manifold i got from vulcan and its a 50 trim t3/t4 turbo im getting a 3" mandrel bent exhaust welded soon!!
Old Aug 11, 2011 | 01:16 AM
looks good! wat all else do you have to do??
Old Aug 11, 2011 | 03:44 AM
just connect the turbo drain back to the oil pan its in the shop now to get the clutch pressure(spec stage 3+) plate and fly wheel(exedy aluminum racing) installed then connect the rest of the piping for the inter-cooler remount the maf sensor then after the clutch gets installed its going straight to the exhaust shop to get a 3" Mandrell bent down pipe then tune and shes running
Old Aug 11, 2011 | 04:32 PM
Leafydialupking's Avatar
The stock MAP cannot see boost. BUT the stock MAF can. Also replace the stock MAP with the 2bar GM late model one. (It can be found by getting the map sensor for the cobalt at a parts store, its actually the cobalt barometric pressure sensor but it is mislabeled in ever parts stock computer system). The maf can be run pre-turbo but you must run a recirculating bov OR you will have rich spikes every time it blows off, no idle issues though (unless the bov leaks).
TurboTechRacing's Avatar
Looks good, need a TTR Intake manifold for your boosted setup!
Old Aug 11, 2011 | 04:53 PM
ya i want one hook it up cheap lol i do want one soon
Old Aug 11, 2011 | 05:46 PM
07cobaltguy's Avatar
I wish i had taken pictures of my Vulcan manifold i just pulled off my car. EVERY weld CRACKED. I just dropped it off at the welder with my junk head. Ive been chasing phantom exhaust leaks for a year, the cracks are now bad enough that you can easily see daylight through them. Be warned. Otherthan that its been a good manifold.
If i were you i would run your maf like 12-18" from the TB if you are going for a VTA blow off, I ran mine in the stock location since we used my cold air intake for that section of charge pipe. Its worked great.
Old Aug 11, 2011 | 06:05 PM
Sounds like you need to upgrade to a TTR one
Old Aug 11, 2011 | 07:10 PM
IonNinja's Avatar
If you have the maf on the intake pipe you will blow off metered air which will cause the issues mentioned above
Old Aug 11, 2011 | 07:13 PM
someday if the wife will let me.
Old Aug 11, 2011 | 07:27 PM
CobaltLs505's Avatar
Who's gonna tune u? R u going trifecta or HPT?
Old Aug 11, 2011 | 07:47 PM
PsychoCam's Avatar
yep like i stated b4 once u fix where ur maf is or recirculate the bov u will be set.
Old Aug 11, 2011 | 07:55 PM
05Slowline's Avatar
sleeper status ftw
Old Aug 11, 2011 | 08:05 PM
bratboy0007's Avatar
Looks good bro! https://www.cobaltss.net/forums/sout...-balts-154744/ check out our NM thread
Old Aug 12, 2011 | 12:27 AM
sweet man i was just going to put it right before the throttle body so i don have to worry thanks for the heads up i would have bin pissed the day i tune it it was running all crapy lol im going with trifecta i have a local trifecta tuner thats going to do a tune within the next week after i get the clutch broken in...
Old Aug 12, 2011 | 12:29 AM
Nice, remember me the one with yellow cobalt with the body kit
Old Aug 12, 2011 | 01:49 AM
IonNinja's Avatar
are you running stock LSJ injectors?
Old Aug 12, 2011 | 03:22 AM
o ya whats up man hows your car running?? and im doing 42# performance injectors
Old Aug 12, 2011 | 09:26 AM
conerboner's Avatar
Don't drive it around without a tune...
Old Aug 12, 2011 | 11:58 AM
car feels great but the only problem i have is a boost leak from my turbo manifold
Old Aug 12, 2011 | 02:53 PM
i wasnt planing on it but its a brand new clutch and i need it to seat with the new flywheel and i don want it to slip while tuning!!! what tupe of manifold did you get??
Old Aug 12, 2011 | 03:42 PM
Zzp
