Next Mod..?
Old May 26, 2011 | 03:25 PM
flyy's Avatar
Next Mod..?
Ok so I've got the Garrett turbo kit sittin' at home waitin' to be installed, megan coils on the way, headlights coming in from streetazn, girlfriend is buying me Tenzo R's, done a little interior work but nothing special so what next?
I've been planning to order a MPx 3" cat-back but haven't really gone through with it yet.
I've more about performance than anything else really, so lets here some ideas..
Old May 26, 2011 | 06:39 PM
BlackCobalt707's Avatar
how about building the engine so you ran run more boost?
Old May 26, 2011 | 07:43 PM
flyy's Avatar
oh yeah forgot to list that, i bought rods pistons and arp studs already so what else?
Old May 26, 2011 | 07:44 PM
07BoostedG5's Avatar
sleeve it
Old May 26, 2011 | 11:59 PM
Originally Posted by 07BoostedG5
sleeve it
if he's on a 07+ block he shouldnt have to unless he's going above 400 (i think thats what the number was, few beers and trying to remember numbers...)
You could always look into a custom exhaust if you want performance/sound, switching between mufflers and resonators and exhaust diameter (just dont buy a "turbo" muffler damn near the most restricting muffler out there)
Old May 27, 2011 | 02:24 AM
flyy's Avatar
hmm thats a good idea i guess i could buy a 3" mandrel from somebody and use that to work from. and yes ive got a gen 2 head. i do plan on going past 400 though my goal is 450+
Old May 27, 2011 | 09:42 AM
really? huh and why is that?
Old May 27, 2011 | 05:17 PM
i'm guessing you're talking about the "turbo" muffler. Its a brand/style that is meant to sound like a turbo (not the blow off exhaust pipe thing) but the problem is it restricts the exhaust like a turbo does.
Click here if you want to learn more about exhaust in general and the turbo muffler
Exhaust Theory
Old May 27, 2011 | 05:40 PM
No Im asking what not sleeve the block if its a 07+
Old May 27, 2011 | 07:45 PM
Gen 2 block in 07+ stronger sleeves they dont replace them until you want to break the 400 number.
Heres info from NJHK from ecotecforums
Significant Updates to the L61 in 2007
Old May 27, 2011 | 09:39 PM
Cool thank you very much for the info, and I thought I was going to have to get my block sleeved!
how is that forum btw?
Old May 28, 2011 | 12:07 AM
Not a member over there, I have the 2.2 build book, but I just google searched to make sure I was remembering correctly. And he knows his stuff, he's on here too.
Old May 28, 2011 | 12:27 AM
Ah ok, well thanks again!
Old May 28, 2011 | 12:41 AM
flyy's Avatar
So is the gen 2 head rated at 400 or 450?
Old May 28, 2011 | 12:57 AM
They say its fine to 400, but i'd be looking into better head studs and def valve springs if you want to get near 400. Although i'm not sure how the head flows stock near that range, for the 400-600hp build they used a sportsman (GM special head, just street pnp'd basically, and some valve seat work).
How much is 93octane across the pond a liter?
Old May 28, 2011 | 01:36 PM
Spanky's Monkey's Avatar
flyy i hope you get this trans. it really does eat the torque up. you could push some serious power through this thing and the lsd is to die for.
Old May 29, 2011 | 04:46 AM
Raiden8816's Avatar
How about brakes?
Thats my plan since the SC is on my car now.
Old May 29, 2011 | 10:27 AM
Originally Posted by Raiden8816
How about brakes?
Solid idea, I dont know why i over looked that, but I did my breaks before i'm adding more power (going SC hopefully by the end of the summer)
Old May 29, 2011 | 02:10 PM
i'm on ebc slotted/dimpled and hawk hps pads. they pull the car back from even the highest speeds. only advice i have is to properly bed the pads and rotors or your brakes will be garbage in a matter of months.
i have a habit of pulsing the brakes when i'm slowing down during normal braking. it keeps the rotors from overheating during most driving conditions. once the brake rotors get too hot they warp when they cool down. repeated overheating and cooling will cause the rotors to warp to the point that your steering wheel will shake during braking.
Old May 29, 2011 | 02:47 PM
NJHK's Avatar
How about doing all your maintenance and making sure everything is up to par.
On top of that, do a compression test before hand so you know where you are before you turbocharge it.
Old Jun 2, 2011 | 07:36 AM
flyy's Avatar
solid ideas and yes i can't wait for that tranny spanky. its gunna be a blast building these two cars. i will do my brakes eventually and yes maintenance is a must ill look into that when i get home thanks NJHK
Old Jun 2, 2011 | 11:46 AM
I would do the brakes sooner than later since you're putting a turbo kit in
Old Jun 3, 2011 | 12:04 AM
flyy's Avatar
true that
well what should i get for brakes ive never stopped to look at whats offered
Old Jun 3, 2011 | 12:51 AM
true that
i bought R1 slotted premium rotors and posi quiet pads, and really like them, they grab pretty good, and i dont think i'll have any overheat/warping issues since i dont try to see how quickly i can stop all the time. I'd guess (never tested) they def stop you shorter than stock, but again my opinion from inside the car, not actual numbers.
But a lot of the guys on here buy Hawk pads.
PM R1 they're a vendor on here, he'll explain it better and you get a ss.net special price.
Old Jun 3, 2011 | 05:57 AM
flyy's Avatar
sweet thanks
StevoElSupremo
Nov 12, 2012 02:13 AM
06_SIC_SS
Apr 18, 2012 08:38 PM
b00sted06ss
Mar 19, 2012 08:07 PM
vpec13
Jan 11, 2009 01:11 AM
Acidangel_5.0
Oct 12, 2006 05:24 PM
