not boosting like it should?? uh oh!!!
Old May 25, 2010 | 09:50 PM
krautsalat's Avatar
don't blame you. I am boosting at 14psi max right now which isn't bad. finally have my a/f dialed in. good luck tomorrow after changing the gaskets
Old May 25, 2010 | 10:20 PM
tru2nrtt777's Avatar
Yeah, good luck man, I am still looking for a few things before I throw it on...
Old May 25, 2010 | 10:28 PM
joshc.'s Avatar
I'm still leaning towards the bypass valve. I've seen this problem before and a new bypass valve corrected it.
Old May 26, 2010 | 01:35 AM
rockstarbass1's Avatar
Bypass valve or actuator?? The vale is the actual vavle in the sc, the actuator is the black canister with the sping in it nand the 2 plugs for the vac lines on it... and it can't be that I took it off and ran with it plugged (so the car would keep the valve closed so it always boosts even when not at wot) and it only went to 10 psi
Old May 26, 2010 | 02:45 AM
joshc.'s Avatar
It was stennguyen1 that had the problem, I just diagnosed it over the phone since I was out of town, I'll get him to come in and shed some light or you can PM him.
Old May 27, 2010 | 08:31 AM
ok cool yea have him post up or something
Old May 27, 2010 | 01:35 PM
joshc.'s Avatar
Well I shot him a text and it was the bypass valve. You can get a new one through ZZP, or find another one used.
Old May 27, 2010 | 09:19 PM
Gene Culley's Avatar
Talking
I really think it is probably how the actuator is lined up. I originally had that problem. I am seeing 15 to 15.5 PSI with the 2.9.
Old May 27, 2010 | 11:28 PM
And that's making my car idel at 1500 rpm also???? Iv messed with that actuator so many damn times tho and took it off and plugged the line idk
Old Jun 1, 2010 | 02:13 PM
Well bringing this back to life.. got my gaskets in, pickin em up after work, gunna pull it all of and go for attempt number 2 ha I really hope this works!!
Old Jun 1, 2010 | 11:15 PM
  #36
wbrevels's Avatar
so howd it go?
Old Jun 2, 2010 | 12:14 AM
  #37
Question damn need some advise still
Originally Posted by wbrevels
so howd it go?
well i fixed my idel problem, not sure what gasket it was but one of them that i replaced fixed it. cleared my cel and it never came back on. car runs smooth and alls great EXCEPT im still only making 11 psi at wot. idk what gives!!!! someone? anyone? oh and i readjusted my bypass actuator and it is working fine i believe. i know someone is going to tell me thats the issue. wich i will prove isnt tom, i will disconnect it plug the vac line going to the sc and the bypass valve will be shut all the time wich then i will do another wot run. if i only hit 11 psi wich im sure i will it means its not the bypass actuator. right?????
Old Jun 2, 2010 | 12:57 AM
  #38
Jn2's Avatar
Jn2
Ur semi right...the bypass valve has a small margin or error, but it does exist...depending on how closed the bypass really is when it pushed down...when u tighten th actuator down notice it gives slack one way or the other before it's tightened down? Be sure the valve on the blower is fully closed when s tightened...
Ps I don't recommend removing that line...don't know what the aftermath of it could b, but with it closed u'll prob make (+) pressure at idle...which would lean u out...just a heads up at 1.5k rpm I can make 6-7psi....at 1.2k I make 4-5...ur on a smaller pulley but I'm pretty sure u'll have some sort of positive pressure without the actuator keepi g the valve open during DD
Old Jun 2, 2010 | 01:01 AM
  #39
ecot3c inside's Avatar
speaking of nipples.. wanna see mine?
/threadjack
Old Jun 2, 2010 | 01:03 AM
  #40
how your making that at such low idel? and if i did plug it and my wideband shows im goin lean id stop right away... but if i dont do that what else can i do im like at a brick wall now
Old Jun 2, 2010 | 09:48 AM
  #41
stenguyen1's Avatar
Originally Posted by Jn2
if the bottom nipple is plugged he will only see 2 mybe 3psi..we acciently did that with interviews cars...that bottom nipple need to be left venting to atmostphere
actually you don't have to leave it venting to the atmosphere. cuz i got mine plugged on a 2.9 pulley and was seeing 14-15 psi at wot.
and the problem i think you having is the bypass valve just like joshc. was saying. i had the same problem not going into full boost at wot. i found out my bypass valve accasionally got stuck open/close so i didn't see full boost. so i switch it with my other blower i had laying around and it fixed the problem.
as seen in this pix i have the bottom nipple plugged.
Old Jun 2, 2010 | 04:06 PM
  #42
Do you mean the actual valve on the blower? Or the actuator? And how do I test to see if its that. I'm broke now and don't have extra cash to just be buying parts and guessing untill I sell some stuff in my fs thread atleast lol
Did my little test again at work. Pluged the vac line going into the blower. So now nothing is hooked up to the bypass actuator. Thus leaving the bypass valve ALWAYS CLOSED. IN THEORY I SHOULD BE BOOSTING A LOT EASIER AND ALWAYS?? Well the vavle is all the way shut and I did a wot run still only 10 or 11 psi.. this means its not the actuator making the issue its something else (when I was done I hooked everything back up how it was)
Last edited by rockstarbass1; Jun 2, 2010 at 04:06 PM. Reason: Automerged Doublepost
Old Jun 2, 2010 | 06:36 PM
  #43
MP81's Avatar
That bottom nipple shouldn't be plugged. It should be open to atmosphere.
Did you ever check to make sure the valve was sitting shut with the vehicle off (aka, SC off the car)?
Old Jun 2, 2010 | 06:44 PM
  #44
stenguyen1's Avatar
who says it has to be open to atomsphere? i got my plugged forever now and didn't have any problems.
Old Jun 2, 2010 | 06:46 PM
  #45
MP81's Avatar
Everyone I've talked to said it has to be open. Mine's open. But if it works, then I guess it doesn't matter.
Old Jun 2, 2010 | 07:45 PM
  #46
either way mine doesnt work lol i need more boost. oh and if you see my other post i have a messed up cv shaft or hub now and dont know how to determine what it is... so now i have 2 issues and no money! great!
Old Jun 3, 2010 | 09:23 AM
  #47
HyperMuffin's Avatar
OP I'm having the same issue. When I decelerate, the RPMs don't go down until I brake it just bounces up and down. Also I have a like 600-700 RPM idle. My other problem is my boost gauge isn't getting a reading at all which means I have a huge air leak somewhere, but I have no idea where.
Old Jun 3, 2010 | 09:54 AM
  #48
coopercharge's Avatar
It definately sounds like the bypass valve they are cheap just pick one up and put it on, I can just about bet that will fix your problem.
Old Jun 3, 2010 | 10:11 AM
  #49
Bypass VAVLE??? Or Vavle actuator??? Litteraly the butterfly vavle or the black canister?
Old Jun 3, 2010 | 10:55 AM
  #50
stenguyen1's Avatar
he means this: http://www.zzperformance.com/cobalt_...=840&catid=189
the bypass valve.
