Oil and Spark Plug Questions...
Old Mar 19, 2008 | 07:09 AM
blu3_v1p3r's Avatar
Ok so I have a few questions...
How often do you change your oil, for those of you that are using synthetic?
What would be the best spark plugs to use in the 2.2?
How often do you think I should change the plugs out?
... I was going by the 3000 mile rule for oil, and the 6 month rule for plugs. I was using the delco plugs i think, and Castrol 5w-30 regular motor oil... Yester I started using Mobil 1 Synthethic, and i was looking for any ideas as to what plugs I should use?
Old Mar 19, 2008 | 07:13 AM
ls1fbody's Avatar
Haz l33t wheelz.
your car should tell you the oil life percentage. if not, you're right to use the 3000 miles rule for the oil, it doesn't hurt to change your oil more frequently than that though. as for plugs, i've never heard the 6 month rule personally, but i doubt its that often, unless you drive really hard, or have a custom tune that causes you to run a little rich/lean.
Old Mar 19, 2008 | 07:17 AM
blu3_v1p3r's Avatar
ok well i've been told that while running sythetic, that we can run it longer in the engine then normal oil, so i was wondering how long people are going with out changing their oil.
and as far as upgraded plugs what do you guys suggest i use?
Old Mar 19, 2008 | 07:34 AM
ls1fbody's Avatar
Haz l33t wheelz.
i've heard that too, but the thing is, my SS/SC came from the factory with synthetic, and it doesn't really matter, the sensors just pick up contaminates and carbon buildup in the oil.
as far as upgraded plugs, im sure theres a thread somewhere dedicated to plugs, and what gaps have what benefit.
rule of thumb <gap, the bigger the spark, and the more complete burn you'll have, but at the same time you don't want to do anything too extrem.
Old Mar 19, 2008 | 07:57 AM
sschevy25's Avatar
they say that you can go up to as much as 7500 mile on some synthetics but i wont ever go that far....synthetic of not...no more than 3000.....plugs i heard could be as much as 25,000...?...
Old Mar 19, 2008 | 11:48 AM
hectanooga's Avatar
I've gone 7800 on regular dino oil. It's really no big deal.
Old Mar 19, 2008 | 12:31 PM
css9450's Avatar
No, it uses a fancy math algorythm based on mileage, RPMs, temps, how many cold starts and how much time spent idling, etc.
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
importkiller
Sep 30, 2015 07:18 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
