opinions needed for future 2.2 tvs build
Old Mar 16, 2013 | 04:22 PM
c1_c1rca's Avatar
Im going to be eventually building up my 2.2 sc to be able to handle the power to add a TVS blower and go with the smallest pulley possible. now my question is what should, or would you guys recommend me doing to my engine before, and what would you guys recommend to get to put out as much power as i possibly can? thanks for the help
Old Mar 16, 2013 | 04:23 PM
BankerBalt's Avatar
need new rods/pistons. build your head. buy a turbo instead
Old Mar 16, 2013 | 04:25 PM
c1_c1rca's Avatar
but i dont really want a turbo tho, i love the whine to my blower and dont want to give that up, its not often around here you hear superchargers, its always cars sneezing, i want different lol
also banker i like how u rhymed lol
Old Mar 16, 2013 | 04:29 PM
BankerBalt's Avatar
lol no rhyme intended. i liked the sound of the blower too but i got bored of the power of the m62. i planned to do a tvs but wanted the gas mileage of the turbo when i'm not in boost. you're gonna want new axles too.
Old Mar 16, 2013 | 04:33 PM
nhanson's Avatar
Port head, valve springs, rods, pistons, neutral or delete balance shafts, get meth or run E85.
Old Mar 16, 2013 | 04:38 PM
c1_c1rca's Avatar
cant do E85, no where here sells it
Old Mar 18, 2013 | 08:46 AM
usafcobalt's Avatar
Yeah definitely will need internals. I'd do a fresh motor. It's not that pricey. But you will need axles. And meth is a good idea. I would just go with rods/pistons crank will be fine. I can help you with the balance shaft delete if you need. I deleted mine for 50cents. F those expensive kits.
Old Mar 18, 2013 | 08:57 AM
you can get plenty of gas mileage out of a sc car when not in boost
Old Mar 18, 2013 | 09:06 AM
MadBrad's Avatar
https://www.cobaltss.net/forums/2-2l...lt-tvs-259686/
Old Mar 18, 2013 | 11:38 AM
IonNinja's Avatar
Pistons, rods, valve springs, head studs, clutch, meth
Done.
Old Mar 18, 2013 | 03:08 PM
lancethrustbone's Avatar
You need only worry about the balance shaft if you are going to be revving the engine up there for long periods. The stock ecu only maps ups to 8125 rpm but the nbs or balance shaft delete would be something to think about if you're going to be doing 7500+ rpm for long periods or frequently.
Valve springs go without saying at that point if spinning that fast anyway.
It is said the stock ones float at 7.1/7.2k rpm
Old Mar 18, 2013 | 03:25 PM
574's Avatar
574
Some guy on here was selling a BUILT 2.2 he had a tvs 2.6 on... maybe you should buy that
Old Mar 18, 2013 | 11:31 PM
nhanson's Avatar
Put a stock pulley on the TVS and you can get away with no engine work right away.
Old Mar 19, 2013 | 01:14 AM
c1_c1rca's Avatar
Done.
this was what i was thinking exactly, but id add in a better h/e, what im kinda worried about is spark plugs, what would i need? and i was assuming i should run 80# injectors as well... but thanks guys a lot for ur input, any more is more then welcome to
Old Mar 23, 2013 | 01:10 AM
scagnetti76's Avatar
Personally I would also add LSD to the list if I was gonna spend the money on fwd.
Old Mar 24, 2013 | 01:29 PM
IonNinja's Avatar
oh yeah I forgot about those lol. Since you are on meth I would go 80s.
For plugs run NGK LTR6IX-11
Old Mar 24, 2013 | 05:25 PM
nhanson's Avatar
Not sure that you would need 80s.
Easier part number for that plug is 6509. Its a big gap too .044
Old Mar 24, 2013 | 06:05 PM
c1_c1rca's Avatar
yeah, im running those for plugs right now, but i have them gapped at .032, i thought with more boost the tighter the gap needs to be?
Old Mar 24, 2013 | 06:44 PM
nhanson's Avatar
Correct.
Old Mar 24, 2013 | 06:56 PM
c1_c1rca's Avatar
YAY! Im not completely rtarded lol
ah crap yes i am
Old Mar 26, 2013 | 03:11 PM
stenguyen1's Avatar
just buy my motor bro. its proven to make power and will come with flywheel and clutch and valve cover and sensors. willing to take 3500 now plus shippng cuz i will use a crating service.
https://www.cobaltss.net/forums/part...ywheel-293715/
Old Mar 26, 2013 | 04:05 PM
IonNinja's Avatar
80s are needed for man size pulley
Besides they'll give some breathing room if he changes setups later on (i.e. turbo)
Old Mar 26, 2013 | 08:52 PM
nhanson's Avatar
Depends on pulley...he never said what size.
Old Mar 27, 2013 | 12:37 AM
c1_c1rca's Avatar
id want to go with either a 2.5" or a 2.6" and as for the built motor.... shipping and customs will butt rape me lol
Old Mar 27, 2013 | 05:39 PM
nhanson's Avatar
For sure 80s then.
