First EVER FULLY Built Sedan Cobalt With TVS!!!!!!!!!
sorry about the quality of the pix. took it late at night. engine bay is really dirty but will get some more later. also will be installing a fuel return system this weekend with a walbor fuel pump.
whatever mike. if you came over this weekend you would of saw it.
Last edited by stenguyen1; Aug 29, 2011 at 01:14 PM. Reason: Automerged Doublepost
here is my build thread.
https://www.cobaltss.net/forums/2-2l...thread-238062/
bates sleeves
Hardened Oil Pump Gears
Neutral balance shafts
10:1 Pistons .020bore
Eagle Rods
Ported Head
Supertech valvetrain
94lb valve springs
oversize Valves with Inconel coating
New Bearings
New Water Pump
Stage 2 NA Cams
Longtube Header
3 inch exhaust with no cat
Magnaflow Muffler
APR Head Studs
TVS with 2.9 Pulley
Dual Heat Exchangers
Dual Pass with Option B
LSJ Map Sensor
80lb injectors
3 in intake
and some other stuff i can't think of on top of my head.
bates sleeves
Eagle Rods
Ported Head
94lb valve springs
New Bearings
New Water Pump
Stage 2 NA Cams
Longtube Header
Magnaflow Muffler
APR Head Studs
TVS with 2.9 Pulley
LSJ Map Sensor
80lb injectors
3 in intake
