P0420 code after zzp 2.5 catted DP
Went to autozone and they scanned it got the PO420 code bank 1. I know other people have thrown codes on zzp downpipe. If I put in a new sensor should the code go away? I also been reading about the defouler but isn't that for the rear o2? Also today when driving a light came on that was never there. First was check engine light, now I have a light on. It looks like a car with a lock on it? What does that mean?
the p0420 is for the rear 02 sensor, it's because of your aftermarket downpipe.There's nothing wrong with the sensor, replacing it won't do anything. A defouler might work, or it might not. The code you had read is for bank 1, sensor 2, which is the rear 02. Just ignore it, or get a tune and have it turned off. The car with a lock on it light is the security light, no idea why that would be on.
^ in MA they hook up to your OBDII. if the is a cat efficiency code, it will NOT pass.
i am having this issue now, and its rather frustrating. i know its my own fault, i chose to put the DP on there. i installed a defouler over two months ago, and the cat monitor hasnt gone "ready" yet.
Well got the defouler gonna put it on. Ifi can get the code to go away I'm screwed with emissions they hook up to ob2 here looked under the hood, they check all monitors. The only thing they didn't check is exhaust not that I have one yet. Hope this work. What's a down pipe that won't through codes on a 2.2?
I thinkk states that are odopting cali emission is a lot more strict. It says on the emisions booth that you can't just clear codes. And al monitors must be set so I don't know atleast I got a year to figure it out!
Yeah but I'm going to be peacing together a turbo. This dp will bolt to the garret elbow and I'm going to get a custom turbo manifold built. So what happens if I have a turbo setup than put stock downpipe back on it??
Well I got a code scanner and defouler. Drilled them out put it on. So far its working. Havnt got a code. The only monitor that's not set is EV? That doesn't have anything to do with a downpipe right?
