pacesetter fabrication?
Old Dec 30, 2010 | 07:37 PM
CobaltMcgee's Avatar
im interested in the pacesetter header but i was looking on www.modernperformance.com and they state "Installation is simple, with one cut needed before the catalytic convertor for installation of this piece". now im assuming this means on the pipe before the cat like the flange? can anyone add some insight to this for me?
Old Dec 30, 2010 | 07:45 PM
1LowLS's Avatar
Right above the top weld of the catalytic converter needs to be cut and you clamp or weld the supplied down pipe to your factory downpipe
Old Dec 30, 2010 | 07:46 PM
TurboTechRacing's Avatar
Exactly, this is how all Pacesetter header kits are to be installed (for all applications)
Old Dec 30, 2010 | 07:51 PM
1LowLS's Avatar
You have any deals going on headers right now?I just supercharged my 2.2 and would like your expert opinion on header downpipe combo that doesn't break the bank
Old Dec 30, 2010 | 07:56 PM
PM us, with which part number on www.TurboTechRacing.com you would like. We will hook you up!
Old Dec 31, 2010 | 10:53 AM
Jn2's Avatar
Jn2
to clear the install up for some of those who havent dont done these, regardless of pacesetters instructions you cant clamps these together...trust me, i have installed 2 of them...if you follow their instructions you end up with a downpipe inches from hitting the ground...
-remove stock downpipe
-remove stock manifold
-cut downpipe right @the top weld on the cat(exactly on the weld, not before, not after, right on it!!
-place pacesetters pipe n flange thing on the place you just cut
-weld the pipe on(you cant clamp bc there is nothing to clamp too(if you leave any pipe to clamp too, you end up with the downpipe hanging low and visible when walking away and to the car from a distance, looks ghetto...not only that but chances r you will scrape it on speed bumps, and steep driveways
-now that you welded it together, put the pacesetter header on
-put the downpipe on
-tighten down the 2 bolts for the header and the downpipe
-turn the car on
-remember to go back the next day and re-trq the 2 header to downpipe bolts
ps- i may be selling my pacesetter and downpipe combo...its still on the car, but i have been putting oremoving it pending nicer weather...but i would sell it with the header and the LSJ dp which is how you should install it to see any real gains, the stock dp is just to retrictive, no one needs that tiny straw piping
Old Dec 31, 2010 | 11:05 AM
chevysssc's Avatar
ZZP has a pacesetter a dp combo used for iirc 200 already fabbed up
Old Dec 31, 2010 | 12:21 PM
thank you everyone for your replys very helpful
Old Dec 31, 2010 | 12:35 PM
C_A_D88's Avatar
sounds like to much work...why wouldnt you just get a bolt in header downpipe combo like the zzp longtube or the vibrant, or the ottp longtube
Old Jan 3, 2011 | 02:38 PM
jdgpuller's Avatar
iam running a pacesetter header on my 2.2 and i just made my own downpipe and 2.5 inch exhaust after that it turned out great
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
Extreme Dimensions
Sep 24, 2015 05:24 PM
Cptnslo
Sep 24, 2015 09:32 AM
