Pacesetter Monza 88-1475 comments
Old Jun 26, 2006 | 03:47 PM
ryneman's Avatar
I bought this exhuast setup for my 06 Cobalt LT. The exhaust sounds great and it deleted my cat. The pipe is the biggest "you can go" 2.6 inches. I love it, I need a video camaro so I can take some vids, any comments for this setup let me know
Here is the HTTP for the exhaust I bought.
http://www.gravanatuning.com/applica...rom_Pacesetter
Old Jun 26, 2006 | 04:37 PM
1SloBowtie's Avatar
It's a very well known setup, alot of poeple have negative things to say about it, but I think it's a decent setup. By the way, it didnt delete your cat, just your resonator, your cat should still be under there if all you did was install this exhaust.
Old Jun 26, 2006 | 04:39 PM
D4u2s0t's Avatar
people say negative things about it, but i'm getting it as well... i think it sounds good on the clips, and for the money you can't go wrong... i don't care if "it will rust and fall apart" in a couple years, because who knows if they're even going to have the car for that long...
Old Jun 26, 2006 | 09:27 PM
ryneman's Avatar
Thanks for replys
Before I installed the exhaust system, I coated it with High Temp. Black cermanic paint. And it did delet the cat. The cat is loacted 3 feet 6 inches from the end of the header. The rear stock exhaust setup that the monza exhaust replaces starts at the cat and goes all the way back, you have to cut the srock exhuast in one place to get it out. The sound is perfect!!! It has a different sound from Honda, Toyota, and Mazada. It revs up and sounds deep and strong, and when the revs drop, it sounds just like my 87 IROC Camaro, I love the product.......
I will put movies and pics up soon...........
Old Jun 26, 2006 | 10:31 PM
1SloBowtie's Avatar
Im telling you, it doesnt remove the cat, only the exhaust resonator. If you look under the hood starting at the manifold, follow the piping down under the car, the cat is at a slight angle upward. There is an O2 sensor after the cat, if you did indeed remove the cat by just changing the exhaust, you'd have to put the O2 sensor somewhere, in which case it would throw a CEL...
Old Jun 26, 2006 | 10:33 PM
06blackg85ss's Avatar
right on... cat is like 1.5 ft from the motor
Old Jun 27, 2006 | 07:00 AM
1SloBowtie's Avatar
If all you did was direct bolt on of the cat-back, it did not delete the cat. Look at these pics...
http://www.imageperformance.biz/imag...%20cfh_cb.html
Old Jun 27, 2006 | 07:30 AM
cobaltltblue's Avatar
true guys i have had mine installed fo r2 months and it does not remove the cat. and i love the sound and price!!
Old Jun 27, 2006 | 08:27 AM
ryneman's Avatar
what the hell does a resonator due, why..............
Old Jun 27, 2006 | 09:33 AM
1SloBowtie's Avatar
Just something to muffle the sound a little more.
CobaltBlue- How are the gains, sound over time, any indication of deterioration/rust?
Old Jun 27, 2006 | 12:52 PM
no actually i had scratched mine on the one bend right before the rear axle and it has not began to rust yet. but it will eventially everything does. the sound is still the same it dosen't have any packing to blow out so it has stayed the same. it's still quiet at a highway cruze!
Old Jun 27, 2006 | 08:56 PM
Veenified's Avatar
any sign of those sound vids being posted?
Old Jul 1, 2006 | 02:40 PM
1SloBowtie's Avatar
Anyone else noticed their coolant running a little hotter since you installed your Pacesetter cat-back? I hardly ever seen mine above 200 with the stock exhaust, but today it went all the way to 221 before it started going down. I mean the exhaust couldnt affect coolant temp, right?
Also, where did you use the rubber hanger that came in the exhaust?
Old Jul 1, 2006 | 06:20 PM
i never used it. the temps are getting higher for me because the outside air is getting hotter. no the exhaust should have little or no effect on your temps. maybe your just driving it harder because it sounds soo good.
Old Jul 1, 2006 | 06:26 PM
HackAbuse's Avatar
Mine should arrive sometime next week
Will write about it after its installed
Old Jul 1, 2006 | 06:39 PM
Mercury's Avatar
I love mine. Sounds like thunder on the 2.0
Old Jul 1, 2006 | 07:22 PM
1SloBowtie's Avatar
Hack, you're gonna love it. It's a little raspy revving it at idle, but under load it sounds very good. Couple of small things, it was hitting the thin metal guard that protects the gas tank, so I just took some pliers and bent the metal out of the way. And there was a bad rattle after driving about 2 miles, found out the longer than stock rubber hanger it came with was in the wrong place, switched it around and it's all good...
Old Jul 11, 2006 | 08:56 PM
vandy0419's Avatar
What do you think it would sound like on a SS/RL since it doesn't have a resonator if a aftermarket downpipe with cat delete...
Old Jul 11, 2006 | 09:02 PM
1SloBowtie's Avatar
PM Mercury with those questions. He has it on his SS/SC.
Old Jul 14, 2006 | 09:43 AM
blueLScobalt's Avatar
i installed the pacesetter cat back about a week ago....1 and 2 second can be kinda raspy with pedal to the floor...but 3rd through 5th sound great...especially above 3500rpms.
i was curious if you could replace the pacesetter muffler with another kind and still use the pacesetter tip....maybe get a little better (deeper) sound.
Old Jul 14, 2006 | 04:54 PM
BaltMod's Avatar
Raspy as in how? Like Civic-with-a-bad-exhaust-system sound? Someone needs to put up a sound file for this exhaust system, cause if it's THIS great, why spend more money on another system? I'll just ceramic coat the whole thing so it won't decay, and even serve a purpose for temps. From what I've been seeing, it'd be cheaper to do all that, and STILL be cheaper than other systems. But I just want a good sound, I didn't buy this car to go fast.
Old Jul 14, 2006 | 05:06 PM
HackAbuse's Avatar
Its gotta really really low tone to it, like chest vibrating. It sounds a little raspy right after you start it up, but after 3-5 minutes it sounds pretty damn good. Its pretty loud too.
Old Jul 14, 2006 | 10:00 PM
BaltMod's Avatar
Anyway to get a sound clip? Hell, call me and and let me listen on the phone.
Old Jul 14, 2006 | 10:01 PM
HackAbuse's Avatar
Theres a video, do a search - Pacesetter Monza Video
Old Jul 14, 2006 | 10:02 PM
BaltMod's Avatar
Will look...
