Performance questions
Old Feb 27, 2010 | 08:15 PM
RacinJared's Avatar
I have a 2006 2.2 cobalt LT and I wanting to put in performance valve springs and a website that I was looking at listed them for 386 US dollars but my question is can I put in valve performance valve springs from an SS camaro or do I need to stick the valve springs made for the cobalt?
Old Feb 27, 2010 | 09:38 PM
BlackCobalt707's Avatar
best bet are valve springs specifically made for a cobalt
Old Feb 27, 2010 | 10:44 PM
xxxxsh4d0wxxxx's Avatar
No.. That's like saying.. I have a Ford Focus.. Can I put in valve springs from a Mustang GT?
Old Feb 28, 2010 | 10:31 PM
RacinJared's Avatar
Yeah I see what your saying I appriciate it guys for responding back guys!!!
Old Feb 28, 2010 | 11:07 PM
no problem. if you want valve springs, check out turbotechracing.com, or ottperformance.com, and zzperformance.com
Old Mar 1, 2010 | 01:18 AM
turbotechracing.com & zzperformance.com
Definitely.
Old Mar 3, 2010 | 06:53 PM
YSUsteven's Avatar
Your gona need to turn more RPM's in order to benifit from better valve springs. If you don't have any plans to go for more RPMs, they are a waste of money. That also means that your gona need new cams as the 2006 cam only makes good power until 6,000.
Old Mar 3, 2010 | 06:57 PM
TurboTechRacing's Avatar
We have direct fitment springs/valves on www.TurboTechRacing.com
Old Mar 3, 2010 | 08:02 PM
s h a y n e's Avatar
so is it correct to assume that with a tune valve springs would be advantageous?
Old Mar 3, 2010 | 08:08 PM
lwrs10's Avatar
Just valve springs? No cam? A waste of money.....you will gain 0 HP
Old Mar 5, 2010 | 09:49 PM
YSUsteven's Avatar
Agreed
The only reason that you would need better springs is if your gona rev the engine higher. With the stock cam, your not making good power above 6,000, and thus if you tuned it with a higher redline, say 7,000, you would not be making more power, and will probably be making less. You need a new cam before valve springs are even necessary.
Old Mar 18, 2010 | 10:39 PM
RacinJared's Avatar
Yeah I see where your coming from.
turbochargedss2012
Sep 20, 2023 12:17 PM
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Oct 13, 2015 09:32 PM
