Piston/Rod Build Need lots of advice
Hey Guys,
Recently bought a 2010 chevy cobalt LT 2.2 L61. Im wanting to do a turbo build on it with about 12-18PSI so I know the first thing that needs to be taken care of is an internal swap. I just purchased the wiseco heads with eagle rods. Ive never done any internal swaps before so Im wondering what build guide/book anyone could recommend that will help this to go smoothly. I have worked on cars before...break pad changes/oil change/spark plug swap/header and intake swap...but I know none of that stuff need be as perfect as internal swaps...any info would be nice guys.
http://www.gmtunersource.com/media/r...mplete-web.pdf
Start on page 9. And if you have a 2010 you have a LAP. So idk if you do the exact same procedure.
Your bore should be good but if you dont have the proper tools you need to take the block to a good machine shop to have the pistons fitted to the bore. Forged pistons take a bit more clearance than the stock Hyperutetic ones. They can put the right crosshatch on the cylinders to promote proper ring break in. Rotating assembly needs to be balanced and might as well get the neutral balance shafts. etc etc etc
How many miles are on the engine? You will probably have to have the rods machined for the aftermarket pistons. When me and my brother did the engine in the cobalt we used diamond pistons. We just honed the cylinders a little bit and put the pistons in. We checked the rings with the feeler gauge and they were pretty much perfect. Also we used stock lsj rods. We didn't even pull the engine to do it. All we did was drop the pan, pull the head, and pull the roads pistons out the top. Made it go a lot faster.
If you've never tuned a car before I would suggest you put the turbo setup on the stock engine at low boost and learn to tune on that, once you get a tune dialed in there you can build another engine out of the car and swap it in, then turn the boost up and re-tune.
Nothing's worse than blowing up your freshly built engine because you dont know how to tune, blocking up a stock engine is a lot cheaper.
Tranny is good up to 500hp as per the gm build book isn't it? Yeah I was going to do the swap with the block still in the car. I wont be doing the tune either...I know a Trifecta tuner down here personally who I will have do it cause Im not interested in messing up my build.. Its the diamond forged wiseco heads...The crank also goes pretty high stock too doesn't it?
