Ported S/C will it help or hurt
Old Aug 7, 2011 | 08:28 AM
gbkglenn's Avatar
I just build my motor and I used 8:9.1 piston and bore 20 over. try to see if a ported s/c with this set up will hurt me ?
Old Aug 7, 2011 | 08:37 AM
MP Cobalt's Avatar
well that low of compression isn't gonna help that blower at all
Old Aug 7, 2011 | 08:50 AM
gbkglenn's Avatar
thats what i was think . i'm going to a 2.6 pulley and a intake spacer . so i'm going to put my old s/c back on .also i got my car tune with HPT by chevycobaltss3 run great we meeting up again in about two week to fine tune thats way i'm try to make all my changes now . I have the 08 HHR
Old Aug 7, 2011 | 10:04 AM
montecarloman's Avatar
Can't hurt to smooth the incoming airflow. Personally with lower compression pistons I'd have put something more effecient on it but thats just me.
Old Aug 7, 2011 | 10:18 AM
Chevycobaltss3's Avatar
:-Pah hahahahahahahahahahahahaha. . Hahahahahaha r u kidding me. Porting a sc out means fine smoothing airflow and opening it up for more cfm. And less heat.... And ect so of course itll help. Anything to lower the iat2z and create more air at a lower flow of air will help! [/B]
Old Aug 7, 2011 | 10:36 AM
gbkglenn's Avatar
ok what is more effecient ? i was thinking that i whould get more boost if s/c was not ported which i think i need because of the low compression piston , my head is ported some also .
Old Aug 7, 2011 | 10:41 AM
cobaltssoverbooster's Avatar
get a tvs
Old Aug 7, 2011 | 10:43 AM
Even if say a engine is lower compression throwing is somthing that pushes more cfm at a lower boost will still help since the volume is larger....
Old Aug 7, 2011 | 10:45 AM
Originally Posted by cobaltssoverbooster
get a tvs
I'd recommend it as the best solution, but its $$$.
Old Aug 7, 2011 | 10:46 AM
gbkglenn's Avatar
I whould love to but i have a hhr I don't think i have enouth room for it , if I knew it whould work I whould get today
Old Aug 7, 2011 | 10:47 AM
Hes also in a hhr and no room.. I dont think itll fit and if it does itll be very close
Old Aug 7, 2011 | 11:45 AM
MP Cobalt's Avatar
um i know what i'm talking about but that low of compression and a m62 is pointless the m62 cant force that much air your best bet would be to go turbo OP
Old Aug 7, 2011 | 11:51 AM
gbkglenn's Avatar
to much money and i don't think i have the room for a turbo i whould try a tvs frist . and i don't know if it whould i think it whould it be close.
Old Aug 7, 2011 | 08:50 PM
Wink
Considering u think u know what ure talking about doesnt count. Boost dont equal power but more airflow on less boost does.. So say ure maf airflow is 35lbs at 3k rpm and then u compare the whp difference on the same engine and ect with the same.boost level as before and.rpm but the maf.lbs is 40lbs. Which one will have the better.power.curve./ whp..... Makin a product that creates more cfm at less.boost means a safer boost and a.safer.power. Which also means if op were to say get his sc ported and install a 2.6 or leave the pulley that he has now. He will make better power with the port job..... Goin turbo is his best bet it truly is but its a dd and ect.... o][/B][QUOTE=MP Cobalt;5960708]um i know what i'm talking about but that low of compression and a m62 is pointless the m62 cant force that much air your best bet would be to go turbo OP[/QUOonsidering the fact that boost dont equal power u dont know what ure talking about.f
Old Aug 7, 2011 | 09:09 PM
gbkglenn's Avatar
what whould be the cost of a turbo? i still don't think i have room for at turbo . i ask a guy about a tvs wait on measurement from him
Old Aug 7, 2011 | 09:24 PM
U have alot of room for a turbo bro log style and ect......
Old Aug 7, 2011 | 09:34 PM
gbkglenn's Avatar
round about cost
Old Aug 7, 2011 | 09:40 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
I built my first turbo set-up for $2500 (this includes EVERYTHING, even a new 3" exhaust system)... sold my GM Stg2 S/C set-up for $1000, and the GMPP Exhaust set-up for $500.
And I went with the more expensive Vulcan Intake and Equal Length Manifolds (Was $1300 worth of manifolds at the time). Replace those with a $100-$200 LK9 Manifold and a $300-$400 Log Manifold... and that's a huge chunk of change saved.
I just helped my friend turbo his Cobalt - only spent $1500-$1700... and sold his stock S/C stuff for $1000.
And why WOULDN'T you have enough room? They make a turbo HHR... and plenty of HHR's have upgraded to larger turbo set-ups.
Old Aug 7, 2011 | 09:44 PM
gbkglenn's Avatar
where did you get it from
Old Aug 7, 2011 | 09:59 PM
Get what from? I put my first set-up together myself. Individual parts from many different shops.
Old Aug 7, 2011 | 10:06 PM
gbkglenn's Avatar
cool , but i don't have the knowledge for all of that for a turbo . i think a tvs may work on my car , just a few bolts to remove i'm ready to go
Old Aug 7, 2011 | 10:08 PM
Omnigear's Avatar
it will waste money =p
Old Aug 7, 2011 | 10:12 PM
gbkglenn's Avatar
whats a waste of money ?
Old Aug 7, 2011 | 10:52 PM
A month before I started my turbo build, I didn't know ANYTHING about turbos or setting one up. You obviously have to do some research... that's how you learn anything.
Old Aug 7, 2011 | 10:56 PM
gbkglenn's Avatar
there a kit on the fourm for 600. i hear what you are saying been working on this to long seem like i with worng with piston
