possible short???
Old Oct 3, 2012 | 07:23 PM
Melon's Avatar
possible short???
ok so my girl has a 2007 chevy cobalt lt i believe. base of the base. not even automatic locks or windows. well anyways, so her driver's side blinker started clicking rapidly one day. which i know a bulb can cause to happen. well then a lil bit after that happeend she completely lost her tail lights as well as her dash lights. so i searched for the issue and found that those problems are linked to the park amp (15amp, under the hood center fuse box area) blowing. so sure enough when i check it was blown. well i replaced that fuse with the spare and then like 2 weeks later same thing happend. her blinker went rapid again but then in a matter of hours the dash lights went out. so i swapped the fuse again. anyone happen to have any idea what this could be linked to? or have this issue? wanna avoid taking it in if we can.
Old Oct 3, 2012 | 10:09 PM
Melon's Avatar
bump. no one?
Old Oct 3, 2012 | 10:26 PM
Validater's Avatar
Possibility of wrong bulb has been installed? Some bulbs can draw more power, I've seen it happen.
If not then yes, you clearly have a short somewhere which blows the fuse. probably a pinched wire then has become unsheathed. A pinched wire with a few strands cut can lower the current flow which would cause the car to think it has a burnt bulb.
Check the bulb first and make sure its the right type of bulb.
Old Oct 3, 2012 | 11:07 PM
Melon's Avatar
Haven't changed the bulb at all from factory
Spanky's Monkey
Mar 7, 2016 06:06 PM
Cptnslo
Sep 24, 2015 09:32 AM
Dustonian131
Sep 23, 2015 08:03 PM
SS_2009_TC
Sep 11, 2015 05:41 PM
shawnsseries
Sep 10, 2015 08:29 PM
