Power steering shit out?
Old Aug 21, 2008 | 12:57 AM
Brenden Griswold's Avatar
Power steering **** out?
I was wiring in the last of my LED's today. Got everything working perfectly. Turned the car on, put 'er in reverse and realized the steering had seized up. So I turn it off and try it again.... after an hour of checking fuses and just basically cussing the **** out of my car and myself, i've given up. Does anyone know what I might of done? I only blew one 15amp fuse and the 20 amp fuse in the passenger side box, I replaced both of those. I disconnected the battery and re-connected it, still nothing. Checked the 60amp EPS fuse under the hood and it look just fine to me...
I will most likely be calling my dealer tomorrow, but I can't drive this thing like this...plus on top of that, I'm a firefighter, so when that pager goes off, I have no choice but to muscle that steering wheel.
Has this happened to anyone before?
Old Aug 21, 2008 | 01:02 AM
Cobalt_SSTuner's Avatar
your probably low on power steering fluid (that was a joke)
EDIT: because sick picked on me i have no idea
Old Aug 21, 2008 | 01:04 AM
sick06cobalt's Avatar
reading > you apparently tuna.... lol... reaed his post...
Old Aug 21, 2008 | 01:05 AM
post edited*
Old Aug 21, 2008 | 01:06 AM
lulz
Old Aug 21, 2008 | 01:08 AM
funny story...i actually attempted looking for power steering fluidz....then i realized it was the 21st century....im guessing I burnt out the power steering motor? who the **** knows, im about 8 beers and 3 cigarrettes over this problem
Old Aug 21, 2008 | 01:10 AM
imma go look at my car quick, stay tuned
Old Aug 21, 2008 | 01:17 AM
tuning....
Old Aug 21, 2008 | 01:18 AM
I know you said that the eps fuse looked fine, but did you actually pull it out and look at it? Secondly, did you check the inside eps fuse? its number 19
Also what did you use as a power source?
Last edited by Cobalt_SSTuner; Aug 21, 2008 at 01:18 AM. Reason: Automerged Doublepost
Old Aug 21, 2008 | 01:25 AM
i pulled the eps fuse out from unda da hood. looked like the others.... I did not check the other one. BRB
#19 looks good too. I'm using #'s 6 (AMP, 20A) and 26 (DR Lock, 15A)
I have two sets of LED's, I have them to two different power sources, and two different switches.
Last edited by Brenden Griswold; Aug 21, 2008 at 01:25 AM. Reason: Automerged Doublepost
Old Aug 21, 2008 | 01:28 AM
u have an ss sc right? cuz idk if 19 is the same for a different model
negative ghost rider..05 LT
Old Aug 21, 2008 | 01:37 AM
idk, the best thing you could do is take it to the stealership. hopefull your under warranty. Did you look over the wires under the column where the steering motor is to make sure nothing came loose? Its pretty hard to see the motor taking a **** without blowing a fuse...
what fuses did you blow on the passenger fuse box?
Last edited by Cobalt_SSTuner; Aug 21, 2008 at 01:37 AM. Reason: Automerged Doublepost
Old Aug 21, 2008 | 01:40 AM
exactly my thoughts. I checked under the steering column, there really isnt any reason why anything would come loose. Although I did breach the firewall (by removing the rubber stopper) so I could run my grille flasher wires to my switch. I'm gonna hit em up tomorrow. looks like I'll have to take the day off.
6 and 26 are the fuses I blew.
Last edited by Brenden Griswold; Aug 21, 2008 at 01:40 AM. Reason: Automerged Doublepost
Old Aug 21, 2008 | 01:42 AM
amp and door locks...huh...yea i wish i could help ya out. i'd have to look at your car to get a better idea. Let me know what you find out, shoot me a pm or something.
Old Aug 21, 2008 | 01:44 AM
im going to call them first thing tomorrow. I'll probably make the death defying drive (30 minutes, half city half country driving) with the manual steering. I'll let them **** with it. I hate it when I cant fix things
Old Aug 21, 2008 | 01:47 AM
yea i hear ya, i'm the same way
Old Aug 21, 2008 | 02:14 AM
Just swapped out the EPS fuses with my sisters LT fuses, no change. Not a fuse problem.... I can't wait to see how much they are going to charge me to fix this one.
Old Aug 21, 2008 | 11:00 PM
ScottxKillyou's Avatar
idk have you checked your lines to make sure there aren't leaks
Old Aug 21, 2008 | 11:04 PM
tru2nrtt777's Avatar
Noob.
Old Aug 22, 2008 | 12:12 AM
FacelessKhaos's Avatar
Unhook the hot and ground from your LEDS and see if that does anything. If it does, then you have a very bad ground on the Pwr Steering Motor. You can ground to the same spot, but wire your hots to something like the wipers or something like that. If it doesn't help, then something overloaded it internally and you shorted it out inside, meaning that one of the copper coils in the motor popped or the brushes burned out.
Old Aug 22, 2008 | 07:25 AM
Busted BCM....$575.50 qoute to repair...just so happens to be covered under the GMPP Warranty
Old Aug 24, 2008 | 07:33 PM
Originally Posted by tru2nrtt777
Noob.
it was a joke dumb ****
Old Aug 26, 2008 | 09:46 PM
damn that sucks! good to hear it was covered under warranty. thanks for getting back to us!
Solaris99
28
Mar 15, 2017 01:22 PM
Fearedbynone
Apr 14, 2016 03:25 AM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
dennis69
Oct 20, 2015 04:49 PM
Stuff
Oct 1, 2015 05:47 PM
