Problems, please help!!!
Old May 9, 2010 | 10:13 AM
jojot's Avatar
A few weeks ago i was driving along slowed to make a turn when i pressed the gas again car had no power. Engine had a bad misfire I cleaned the throttle body, changed plugs and it ran fine up until Friday night it basically did the same thing stopped at a red light and it just lost power. I had the cel checked and 3 codes p0420, p0300, and something about the temp too low, changed thermostat, and plugs it ran fine for about five minutes then same thing, new plugs are smutted up and #2 is wet. Don't know what else to do anybody else had this problem, any suggestions on what it could be? 2006 ls 2.2 145,000 miles
Old May 9, 2010 | 10:20 AM
stavros's Avatar
when changing plugs did you mess up the coil pack?
Old May 9, 2010 | 10:22 AM
07cobaltguy's Avatar
sounds like your coil pack crapped out on you.
Old May 9, 2010 | 11:13 AM
jojot's Avatar
I was thinking coil pack or now that i'm doing research i'm seeing all of these post about the cat recall, would that possibly do it also?
Old May 10, 2010 | 08:23 PM
could be either or.
Old May 11, 2010 | 08:11 PM
tru2nrtt777's Avatar
If it is the coil pack I have a spare, LMK if you need it.
You said #2 was wet? What was on it? Gas? Water? Oil?
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
