Pulley FOR 2.2?
Old Nov 25, 2009 | 01:04 PM
boltedbalt's Avatar
Pulley FOR 2.2?
what site sells the under drive pullies for the 2,2's? i cant seem to find them anywhere?
bumpssss...
Last edited by boltedbalt; Nov 25, 2009 at 01:04 PM. Reason: Automerged Doublepost
Old Nov 25, 2009 | 01:05 PM
hackeragent061's Avatar
MRZ performance
Old Nov 25, 2009 | 01:22 PM
boltedbalt's Avatar
I never really understood the pro's and cons's of each and was wondering if some light could be shed on them?
Lightweight Alternator Pulley - Ecotec 2.2/2.4 - 5 ribs
2.2 2.4 Ecotec UDP - Underdrive Crank Pulley L61 LE5
2.2 2.4 Ecotec Lightweight Crank Pulley L61 LE5
Bump Please!
Last edited by boltedbalt; Nov 25, 2009 at 01:22 PM. Reason: Automerged Doublepost
Old Nov 25, 2009 | 01:23 PM
http://cobalt-addiction.com/performance.htm
Old Nov 25, 2009 | 01:27 PM
boltedbalt's Avatar
thanks very helpful! If i got the under drive pulley is it a must to get the shortened belt? and which one in theory could create more Hp one a modded vechicle?
Old Nov 25, 2009 | 01:40 PM
using lighweight pulleys r about 2lbs less then a stock pulley so it puts less load on ur engine, frees up a free hp if you modded, and helps u rev out faster,
based on way mods i see u hav and r goin to get, a lightweight pully will give u a little gain and yes u need a shorter belt but its just a little short, but do this add a last mod b/c price/power ratio u dont get much
Last edited by hackeragent061; Nov 25, 2009 at 01:40 PM. Reason: Automerged Doublepost
Old Nov 25, 2009 | 01:55 PM
1niceLS's Avatar
yeah you wont really see any hp numbers but you will feal a difference I have both udp and alt pulley and the car revs a lot faster and please for the love of god dont buy the shorter belt online go to your local auto parts store and buy one for cheap
Old Nov 25, 2009 | 02:52 PM
boltedbalt's Avatar
so really the best combination would be both? and factor a tune after the pullies it make turn out to be quite a power adder...
Old Nov 26, 2009 | 02:27 AM
Jn2's Avatar
Jn2
2.8" pulley is the way to go
Old Nov 27, 2009 | 05:11 PM
1niceLS's Avatar
It would be if he was supercharged
Old Nov 27, 2009 | 08:49 PM
Jn2's Avatar
Jn2
Than a pulley alone won't make a significant difference...
Old Nov 27, 2009 | 09:53 PM
06_ion2's Avatar
yes for me it could lol i would love to have a 6 rib setup and a sligtly shorter belt so i dont need to special order one soon.
Old Nov 28, 2009 | 08:48 AM
1niceLS's Avatar
You sir are correct
Old Nov 28, 2009 | 05:02 PM
2007victoryred's Avatar
Would there be any difference with the lightweight crank pulley and alt pulley?
Old Nov 29, 2009 | 07:24 AM
vash90909's Avatar
By having them lightweight the engine has less of a load to try and turn. This allows the engine to spin faster thus quicker revs and with less of a load more hp(very little tho). Do it more for the revs so you can get to your powerband quicker and thus faster 1/4s!
Old Nov 29, 2009 | 02:00 PM
Maven's Avatar
ohmigosh, again...............
Old Nov 29, 2009 | 02:09 PM
06_ion2's Avatar
Hai!
Old Nov 29, 2009 | 03:47 PM
jbenso4's Avatar
been there...done that...not worth it...but whatver floats youre boat
Old Nov 29, 2009 | 04:08 PM
So its a complete waste of time and money? It sounds like something I would like to have. I would love it if my car were to rev quicker.
Old Nov 29, 2009 | 04:55 PM
1niceLS's Avatar
sounds like someone has already lectured about this before
Old Nov 29, 2009 | 09:44 PM
06cobaltindallas's Avatar
have you looked into the ati super damper?
expensive but well worth
Old Nov 30, 2009 | 05:44 PM
1niceLS's Avatar
Please do tell....
Old Dec 1, 2009 | 01:53 AM
the gm drag cars run the super damper with no problems up to 1400 hp.
it is already balanced and can with stand high rpm abuse.
i dont know as to how much it weighs but its better made than most
costs bout 410 through summitt racing
Last edited by 06cobaltindallas; Dec 1, 2009 at 01:53 AM. Reason: Automerged Doublepost
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
