Question
Question
I have the 3" Magnaflow carsound cat on my 2.2 and its not where the stock one used to be its further down the line right under the big heat shield however its a good 10" from where the stock one was and I keep getting P0420 or P0402 codes : Catalyst not working within established parameters. I was wondering if maybe its: 1. not hot enough being its further back and 2. Its too big for the engine. My solution to #1 was to get the heat wrap tape and do from the header to around the cat to keep it warmer inside the pipe and thus allow the cat to work more "optimumly." Think it will work/help?
if you have the cat down past the second oxygen sensor, it's going to throw those codes.
you need the exhaust to pass through the cat first and then flow over the rear o2 sensor
if you have though, there's a good chance it flows "too much" and isn't working enough. the heat wrap idea may help but I wouldn't put all my faith in it
I bought it from Gravana and they said that the 2.5" was more expensive then the 3" and I asked about it being to big and the guy said not to worry about it and it should be fine.
In my opinion, and what i plan on doing is buying the complete catalytic converter system thats on a cobalt ss/sc. I done some research and after looking, the ss has bigger pipe going into and after the cat compared to my 2.2L, not to mention its all oem stuff so no codes, and no voiding of warranties.
It not only has a 3" downpipe, but has 2.5" piping all the way back until after the rear axle and slims down to 2.25".
Now I shouldnt' be talking because I've got a full 2.5" catback and will probably end up with 2.5" piping from the header back
Iceberg
Sep 29, 2015 12:33 PM
